Anglepoise
Just finished my first \'Light Engine\'......?
I bought my first Aleph II last week , and all it needed was a LE.
I chose a Wizard 2, at 750 ma because I wanted to use a single re chargeable r123 battery and the Wiz has a built in cut off at around 2.8 volts and this will make sure that I do not run the r123's to the danger area.
Soldered it up today and boy does the epoxy set fast. Just got the E screw on in time.
I am going to need a 5 ohm total resistance to make the second stage work well in the switch.
Anyway my question. The o ring does not stop the reflector moving forward all the time. Now I realize why some builders epoxy the reflector so it stays in place. I do not want to do that and need some advise from members that have found the same thing. The o ring starts off fine but gradually slips down the side.
