Hi all,
Looking for some advice/trouble shooting ideas regarding the driver I am using for my light mod.
I know that at least Packhorse has used these drivers (as I got the idea from him), but I'll guess others here will have some input also.
I have previously had this set-up running and working fine, but then after a necessary re-build of the canister and light head I've come across some strange issues with the drivers. Upon connecting everything up I have had a couple of different things happen.
1. Nothing at all. But then upon testing with multi meter I discover that somewhere between the - supply attaching to the driver and the - going to the LED I guess I loose connection. That is if I test + & - going to the LED I get nothing, but if I keep multi meter on the + on LED and ground further back down the line I then get a reading (sorry for my bad explanation).
2. All was actually working properly (with another driver), then it sat for a couple of days and then upon re-connecting the light flashed on and cut off. This has now left me with the same scenario as point 1.
All of this leaving me rather confused and frustrated, especially since it has worked previously.
Below is the link to the drivers and also some pics.
Link to driver:
http://www.kaidomain.com/product/details.S006371
Above: + & - from battery and switch, etc.....
Below: + & - to LED (XM-L). (Orange and ? is a resistor(I think) that mine don't have. Not sure if that's important or not though)
Does any of this make any sense to anyone??
Cheers,
Joel.
Link to driver:
Cheers,
Joel.
