Klarus ST11 + CH11 charger Review
FlashLion
Europe
Hello
As you know I am a Klarus fan and their tactical lights are my favorite.
They released new ST models with a design which is more suitable for general use.
I asked Klarus to send me one of these models for review.
And here it is.
These are my impressions and what I think about this flashlight.
First impressions-
-A high quality product
-Nice design,this time not tactical,a little bit heavier than expected-thick aluminum is used here. Looks like from Klarus do not save aluminum.My measurements show that the ST11 draws 2.5Amps from a fully charged battery.So the minimum current to the LED is 2.5A.At this current the XM-L2 led starts to produce a serious heat.So the use of a thick aluminum is justified here.It's needed for the flashlight to handle all this heat,for extended period of time.
-Excellent dark grey finish with extremely well made knurling and anodization.Just perfect.
-The knurling is shallower than the previous tactical models.
-Nice anti-roll shape.
Specifications from the manufacturer:
1. CREE XM-L2 LED with a lifespan of up to 50,000 hours
2. Lighting modes: High/Medium/Low/Moonlight/Strobe/SOS
3. Working Voltage: 3.0V-8.4V
4. Battery: 1x 18650 battery
5. Body color: Gun Metal Grey
6. Reflector: Smooth reflector /orange peel
7. Lens: Toughened ultra-clear glass
8. Dimensions: 141mm (Length) x 36mm (Head) x 25.4mm (Body)
9. Net weight: 146g (Excluding battery)
1.CREE XM-L2 LED, delivering a maximum output of 900 ANSI lumen.
2.Patented Tail-cap & Side Switch design, allowing easy access to power settings.
3.Easy-access Strobe feature can activated at any time
4.Ergonomically designed for one-handed operation.
5.Specifically designed tail cap allows upright 'Candle' hands-free use.
6.Waterproof design rated to IPX-8 (waterproof to a depth of 2 meters).
7.Stainless Steel bezel design protects the lens and reflector system from drops and impacts.
8.Intelligent control circuits balance brightness, run-time and heat emission for improved performance.
9.Optical lens system allows for illumination up to 100 meters.
10.Anti-shortcut design prevents accidental damage to internal electronics.
ST11 comes in a good simple package.In the box you will find a lanyard,spare O-ring and instructions manual.
No holster included.This time they let us decide what holster to choose.So it's good idea to ask for a holster when buying.
-It has the most transparent glass I've ever seen-I can't see it is there.Excellent anti-reflective coating.
-I expected to get a flashlight with a smooth reflector...-no I got the OP version.
The reflector is the same size as the XT11 and RS11,but with a little different texture.
-The LED is absolutely perfectly centered.
The screw threads are excellent crafted-anodized,square cut,very smooth screwing.
r
The side switch is just what it should be.Right size,position and feel.It's not easy to to find it in full darkness,but you can't expect to be otherwise from a side switch.
It has a sound tipical for the electronic switches.
I am little surprized,the tail switch has a little louder clicky sound than the XT11's switch.Maybe this is due to the different mounting position.It is also not so soft on pressing.
On the back you can see the stainless steel ring(it protects the tail from impact) and rotatable lanyard loop.
The stainless steel ring is removable,you can change the switch or the switch cap.
Forward tail switch with momentary on feature.
Rotatable lanyard loop-Very nice idea.I don't use a lanyard with flashlights this size,but this is a good option.
It allows the flashlight to stable tail-stands even with attached lanyard.
The battery tube is very well sized.There is enough space even for a big batteries like Sanyo Protected.
There is a gold plated spring at both ends for maximum efficiency-minimum losses of resistance.
For maximum performance I feed my Klarus ST11 with one of the best 18650 batteries-Keeppower 3400.
I highly recommend these batteries.Maximum capacity,built in compact protection circuit,safe.
The cell and the IC are made in Japan.Something very important-the 3400 mAh is the same length as the shortest protected battery that I have-Klarus 2200mAh flat top.This ensures that the battery will fit in every flashlight.
The 3400mAh battery provides the maximum possible runtime for a 18650 battery.
The pocket clip looks the same used in XT11,so careful with it.Can be attached at the head side,which is a good option. It is very tightly pressed to the body and I think I will remove it in the future.I also don't use a clip for attaching flashlights this size.
Reverse polarity protection protects the flashlight and battery from damage.
On the front you can see the stainless steel bezel-this time not crenelated.Very stylish and well made.Just the right size.I personally prefer a crenelated bezel because I can see if I forget to turn off the light and leave it on the table.
The smooth bezel is more convenient for general use light and appropriate for carrying in a pocket and is also safer to leave the flashlight in the baggage.
VS Klarus XT11
If you expect a throwy shape beam from ST11,don't.
It has a similar beam to the XT11 with a difference in the spill,it is brighter,smoother and homogenous.
ST11 is definitely brighter,but you will not see it if you look only the center of the beam.Of course the spot is brighter than the XT11's spot,but not so much as I expected.The difference is most in the spill-it is very nice smooth and very bright.This is a lot of useful light.To see how much brighter it is,just leave it on a table,tail-standing and you will see that it pumps out a lot of lumens.This is a wall of light.
I found that type of beam very useful once I got used to Klarus XT11.Even the beam is floody,it still has enough throw for normal use.
The light from the XM-L2 is whiter,no yellowish or greenish tint.It's better than the light from XP-G2 lights I have.Just perfect for a cool white LED.
From the manufacturer:
Peak beam intensity 7817 Cd
Max beam distance 177 meters
distance= 1 meter 1/20 white wall
Klarus ST11 uses a PWM regulation for changing the different lighting modes.It is quite high frequency 1.56KHz.
There are 4 lighting modes and 2 flashing.High 900Lm-Medium 225Lm-Low 15Lm-Moonlight 1Lm- in that order.
The flashing modes are SOS (with good speed-not too fast) and variable frequency strobe.
"Note: All specification data was achieved using 18650/2200mAh/4.2V batteries." -I find this in the specifications.
The PWM is not detectable on High brightness mode,on medium and low can be detected with a cooling fan.On moonlight is easy detectable.
Something very interesting and important in this model.As many other lights it makes a step down in the brightness after a few minutes in High mode.
I waited to see it a few times,with no result.After a few tests I found that the driver starts to change very slowly a PWM signal to the LED at the 4th minute and stops at the 5th. This means that ST11 makes a brightness step down in a minute and is impossible to see this step.Well done:twothumbs
UI-
from manufacturer
Operation:
A Tail Power Switch:
1.While OFF: Lightly depress switch to activate momentary-ON
2.While OFF: Fully depress switch fully for constant-ON
3.While ON: Fully depress switch for OFF.
Other functions please reference to B, C.
B Side Switch
1.While OFF: Short press (< 1 seconds) to activate momentary-ON
2.While OFF: Long press (> 1 seconds) to activate constant-ON
3.While ON: Long press (> 1 seconds) to change MODE.(High/Med/Low/Moonlight)
4.While ON: Short press (< 1 seconds) for STANDBY.
5.From ANY mode: Fast double-press to activate STROBE. Press the switch again to turn STROBE off. (The Tail Power Switch MUST be turned ON)
6.From STROBE mode: Long press (> 1 seconds) for SOS.
C Memory function:
When a lighting mode is on for more than 3 seconds, the mode will be memorized. The device will return to this mode when turned on next.
Off/Standby function:
The Tail Power Switch will completely power-down the torch when turned OFF, preventing accidental activation of the side switch whilst the torch is in storage or being carried in a pouch.
My thoughts:
Can be used as a single mode flashlight.Just leave it on the mode you want to use for 3sec,then turn it off with any of the swiches.After that every time when you press ON the tail switch it will come on the mode you chose.The tail switch can't change the brightness mode.This way you have a single mode flashlight with momentary on function.Great;)
Fast double press activates variable frequency strobe.It alternates 17 Hz and 7 Hz.
From strobe-long press activates SOS.
Beamshot comparison
Distance 5 meters 1/6 sec , f3.4 WB and focus locked
Klarus ST11 High - Medium - Low
Klarus RS11, Klarus XT11, C8 XM-L T6, C8 XP-G2, 52mm SMO XM-L T6, 26mm SMO XP-G R5
1/50 sec , f 3.4 WB and focus locked
Klarus ST11, Klarus RS11, Klarus XT11, C8 XM-L T6, C8 XP-G2, 52mm SMO XM-L T6, 26mm SMO XP-G R5
Klarus ST11, Klarus RS11, Klarus XT11, XTAR B20, C8 XM-L T6, C8 XP-G2, 52mm SMO XM-L T6, 26mm XP-G R5, 26mm XR-E Q5, Klarus RS16
Distance 40m 3.2 sec ,f 3.4 , ISO 80 , WB and focus locked
Animation- ST11, XT11, RS11, XTAR B20, C8 XML, C8 XPG2, 52mmSMO XML, 26mm XPG, 26mm XRE Q5, Klarus RS16
Good grip. The thicker part at the tail helps for that.
CH11 charger
-Optional
Unique feature for ST11 and STC2. Portable charging unit. Screw on instead of the head and plug the supplied cable to USB or 5V AC adapter.
Well packed in plastic case. Included -charging cable USB>MicroUSB, 31cm/12.2 Inch lenght, instructions manual.
The supplied cable is long 31cm/12.2 Inch,good for charging from laptop.
I usually charge with 1m/~40 Inch Micro USB cable for Nokia cellphone.
Specifications
1. Easy-carry screw-on charger for ST11 Torches
2. Compact and Lightweight design (just 16.8g)
3. Used for in-torch recharging of Li-Ion batteries
4. Reverse polarity protection
5. Micro-USB to standard USB cable supplied
6. Can be used off any USB port (5V/500MA output required)
7. Features three charging modes (CC, CV and Trickle Charge)
8. Automatically stops charging when complete (4.2V cut-off)
9. Charging Indicator lights for easy reference (red and green light)
More info can be found at the Klarus website.
After about 10 times charging,I can say-this is the best charger I own. Never exceeds 4.2 volts. And even better-I left a Sanyo 2600 protected battery in it after charging complete at 4.197V,for 2 more hours and the voltage was still 4.197V. This is just great for such a small charger.
There are three charging indicator modes.
Green with blinking Red-the tail switch is OFF-It should be ON to make connection to the negative battery contact.
Red light-Charging
Green light-Complete
One recommendation from me-When the charging is complete,turn OFF the tail switch,because when you screw on the flashlight head and the switch is turned ON,the light will start automatically on the last used brightness level.
Thanks for reading!
Special thanks to Klaruslight and schiermeier.biz for providing ST11 for Review!
Re: Klarus ST11 + CH11 charger Review in Progress
Thanks for the review :)
I still have to buy this light and the ST2C ;)
Thanks for posting.
Can Someone that has this light with a smooth reflector post a simular beamshot to show the difference?
Very nice review, great pictures too
Thanks
I own two ST11's and I am most happy
Thank you all for your comments. :thumbsup:
My review is almost complete.
You will find lots of new beamshots and a runtime graph.
I will add also videos when I have a free time.
Thanks for reading.
Thanks for reading.
I just purchased the CH11 and I find this a great feature for charging options.
I always carry extra batteries when traveling and having this simple charger is a nice option.
Your suggestion of clicking the tail switch off first, before removing the charging head, is a nice tip, thanks
I now have four Klarus lights and they all work as needed and no problems.
Again, nice review, good job.
Is this ST11 a fully regulated or semi regulated ?
I never seem to know the difference.
Thank you!
Congratulation! 4 Klarus lights is a great number.All these lights are excellently machined.It's hard to find other so smoothly machined lights.
About the regulation,I am not sure what are the requirements for a flashlight to say it's fully or semi regulated,especially when there is a brightness step down.
This may be helpful. Comparison Klarus ST11 Vs XTAR B20 (XM-L U3,Smooth reflector)
ST11 on the left.
Even with an OP reflector ST11 has pretty good throw.For better throw,I think something bigger is needed.
Nice job!
I'm looking forward to seeing if its brighter with two 18350's and/or two RCR123's, the way the XT11 is.
:D
Nice job!
:D
Hi, TEEJ
I did a test with two Sanyo 2600 (18650) and no luck for you.
ST11 is very well regulated and the brightness with two 18650 is absolutely the same.
Current draw with two batteries U(no load)=4.05V each.
I one=2.10A
I two=1.4A
bump: On the strength of this review, I took advantage of the GG sales before Xmas and picked up an ST11 and the charger. Neat idea, admittedly slow due to obvious heat dissipation considerations. End voltage ~4.15 on an AW 2900 cell. The ST2C charger ends it's charge at a slightly lower voltage. that is common with most internal charging circuits. The design errs on the safe side.
More importantly these chargers may break the travel barrier for me due to their compact size. I normally take 1xAA-based light on travel because of space considerations. A Sanyo 2xAA charger is small - very important. This is the first 18650 charging system that meets my tight space requirements. ie: I never take a suitcase on trips, maybe only a so-called 22" carry-on w/o any expansion if I will be gone for a month or more.
Thank you for the review and update video. I will put the USB charger on my list now. Where can I purchase your recommended Keepower 3400 cell for this flashlight here in the UK?
I have never seen Keeppower batteries being sold by the UK resellers I bought flashlights from. The only place I know in the EU that sells them is nkon.nl. They have good prices but you need to take into account shipping charges so I wouldn't buy just one 18650 battery. In the UK you can easily find the Fenix and Eagletac 3400 mAh batteries: a bit more expensive but if you buy just one battery and get free shipping it would turn out to be cheaper than buying Keeppowers. Before buying whatever brand, just make sure the size of the 18650 will work fine in your ST11.
Hello.
The battery tube of ST11 is well sized and any 18650 battery should fit well. You can use any 3400mAh battery. Most flashlight brands offer batteries with their name,but inside the batteries are the same. Just buy batteries from any trusted,well known brand. Never buy batteries with the word Fire in their name.
