Klarus XT10 Switch malfunction
Bruno28
Australia
Hey,
Today i wanted to charge all my flashlights, I keep the Klarus xt10 in my car, only if I need it for any reason.
As i was turning it on, the switch is very sensitive and if i leave it ON and I just touch the switch (without pressing the click), the light flashes and blinks. Seems to have a bad contact or something.
Anyone experienced this?
Check the retaining ring on the inside of the switch. You will see 2 small holes. Find a tool that fits these holes and tighten the ring.
do i need to remove the rubber switch? How do I remove it?
To tighten the retaining ring, you don't have to replace the rubber-cover for the switch.
To remove the rubber cover. Take out the retainer ring. Take out the switch, washer and the rubber cover.
Ok thanks, ill give it a try.
You just need to tighten the inside of the tailcap by inserting the needlenose pliers into the 2 small holes you see in the picture below from another thread.
If you don't have pliers with tips thin enough you can use the scissors from any Victorinox knife - I found they work very well for tightening tailcap retaining rings.
Here's a picture of the inside of the tail switch.
