L4 168 question
Pydpiper
Brantford/Woodstock
Would there be any benifit to modifying a L4 to accomdate a 168a opposed to a 168s? I use my lights daily and any extra runtime would be a treat.
I tried to search this subject and came up empty, a link to some guidance would help.
Thanks..
Pyd.
Hello Pyd,
Welcome to CPF.
I ran a comparison of the 168a and the 168s in the "U2 Battery Comparison" thread.
Tom
So I see the 168a is a superior battery. Am I reading the graph correctly and I can get 80 min out of an L4 with the 168a? Would there be any negatives?
[ QUOTE ]
SilverFox said:
Hello Pyd,
Welcome to CPF.
Tom
[/ QUOTE ]
Thank you Tom, excellent graph.
Hello Pyd,
I don't believe the 168a will fit in an L4 body. It is bigger in diameter. For the L4, you have to go with the 168s.
The U2 with accommodate either.
Edit: I see from the first post that you were planning to bore out the L4 body to take a larger diameter battery. Oh well, this is good information for those who have stock L4's.
Tom
Thanks guys, this is the info I was hoping for..
I never considered the effects of thinning the walls of yhe L4..
I wasn't sure if it was common to mod the sleeve to accomodate bigger batts, now I am starting to see the 168s may be best for the application.
