[ QUOTE ]
Quickbeam said:
I've been reluctant to try this because of the lack of washers - now that the 123 battery washers have been found, I thought I'd give it a shot.
I cannot believe the difference this has made in both my Z57 clickies.
Thanks to all involved!
[/ QUOTE ]
Did you shunt the small spring when you had it apart?
[ QUOTE ]
StevieRay said:
Well, as luck would have it. I couldn't get the retaining ring off of mine.
I boiled it twice for 5 - 10 minutes. So I said, "Why not just spray some silicone done inside, otta loosen it up." Well it is now stuck in the on position! /ubbthreads/images/graemlins/crazy.gif /ubbthreads/images/graemlins/confused.gif /ubbthreads/images/graemlins/mad.gif
Can anybody help, please?
[/ QUOTE ]
Steve, you didn't get it hot enough. I don't use the boil in a bag method, I use a heat gun, which works every time. Before I had the heat gun, I would press the clickie directly to the element on my electric stove for about 10 or 15 seconds which also worked without fail. If you can't get it to work, you could mail it to me and I'll fix it up free of charge.
Peter
