windstrings
I have posted this on another forum too in hopes of an answer, but
I am really getting confused here and so far I have not gotten any returned emails or feedback concerning this issue.
I"m debating over the Aries 175mw thats rated with a typical peak output of 215mw for 629.00 or to add another 120.00 and get the Optotronics RPL 165 with a peak of 225mw?? All things being equal, I would be paying for the larger diode, LiIon battery and charger I suppose.
The Optotronics has a 2.5 watt diode verses the 1.2 watt of the aries.. I'm not sure I'm seeing the "benifit" of all that diode since the peak is virually the same.
I have conceded to the fact that I do not want something as gargantua as the hercules even though I'm sure its a stellar performer.. I cannot carry something that big.
Both of these lasers in question are virtually the same size.
***One real concern I keep bumping up against is thier own review that speaks of the units shutting down within 50 seconds or so with thier RPL 260?
Below are quotes from thier own review link from thier site....
http://ledmuseum.candlepower.us/sixth/rpl-260.htm
A laser of this quality and with such a heat sink should "not" be shutting down!..... the laserglows boasted of running 200 days consecutively and even thier power ratings are over 10 minutes rather than 20 seconds as the Optotronics unit.
Surely this "overheating" issue has been corrected.. I understand now that units over 250mw have fans "which I don't desire either" as it will be noisy and only pull by battery down more.
the other concern I have on the review is the statement that:
I cannot find anywhere on the Optotronics site about any graphs that show thier runtimes or any boast of how long they run, nor is it mentioned in their Faq page?
This is quite a concern that needs to be addressed.
I hope in my ignorance I have not stirred the mud, if so I will edit this post to correct any irregularities or inaccuracies.
I am only seeking the truth so I make a good purchase.
I would have kept all this private, but no one will return my questions?.. maybe its the holidays???
I quite frankly would rather have the same size unit with the bigger diode and LiIon battery if everything else is reasonably equal, but something doesn't add up here in my calculations?
Does anyone have any reviews of the Optotronic units??? Can you tell me how long thier duty cycle is? Are they "continuous output" units as laserglow boast their 6 hour runtimes?
I wouldn't even bring this up but I've seen post of other folks asking the difference between the two and replies saying that "Optotronics" was the best handsdown?
Can someone please enlighten me here?
I don't want to make a purchase I will regret later because I was misinformed.
Since this is a high powered laser, I would recommend a duty cycle of no longer than 37.5%. That is, 30 seconds on, and at least one minute off to allow the "guts" inside to cool down. This is not stated anywhere, but is my own recommendation.
This laser has an automatic thermal protection circuit; if the laser is operated continuously for ~50 seconds, the beam power output will drop sharply; to perhaps 5mW. When this happens, turn the laser off and leave it off for at least one minute to allow it to cool, then you can turn it back on.
When timed with a clock with a second hand on it, this thermal cutout engages in exactly 67 seconds. The ambient temperature for this test was 81°F (27.2°C).
CURRENT CONSUMPTION: Was asked not to measure
