Luminocity
/ubbthreads/images/graemlins/help.gif
I've had some sporadic issues with my LC100 where it sometimes won't strike, even with fully charged batteries. Removing the bulb and reinserting it often resolves the issue for a few days, and then it surfaces again.
To make a long story short, I took it completely apart to check for any kind of loose connections and now I realize that I forgot the correct orientation for the rubber shock isolator (the dealy that has the position key) for the bulb. /ubbthreads/images/graemlins/confused.gif I put it all back together, but I had to guess on the position of the shock isolator. This means that I have a 50-50 chance of putting the bulb in correctly. Not odds I want to play for a $60 bulb!
I did notice that the there is a round black dot on the PCB of the socket that appears to be a pin marker. The mark on my socket could be considered to be either an upper left pin idintifier or a lower right identifier depending on the orientation of the module.
Can some you LC100 owners pull your bulb and see if this mark exists? If so, what is the position of your mark?
Here is a picture of the black dot on the PCB of the lamp socket:
Many thanks.
Many thanks.
