Since I searched for any similar R5 threads and nothing found
A few hours ago the LD01 R5 stainless steel Christmas 2010 design was officially released.Here are the specs:
• Cree XP-G LED (R5) with a lifespan of 50,000 hours
• Uses one 1.5V AAA(Ni-MH, Alkaline) battery
• 76.2mm (Length) x 14mm (Diameter)
• 35-gram weight (excluding batteries)
• Digitally regulated output - maintains constant brightness
• Patented physical structure avoids circuit damaging from reverse connection of battery
• Reliable twist switch
• Capable of standing up securely on a flat surface to serve as a candle
• Made of durable stainless steel
Notice: The above-mentioned parameters (tested with 750mAh Ni-MH batteries in Lab) are approximate and may vary between flashlights, batteries, and environments.
Imageshack.us
http://www.fenixlight.com/viewnproduct.asp?id=80
Imageshack.us
