LE full size flashlight?
Gmwilkes
____I would like to purchase the light from a brick and mortar store. I am located in ______________.
_X___I will be mail-ordering or buying online, so this doesn't matter.
2) Budget: An easy question, but you may change your mind after answering the rest! :-)
____Less than $25.
____Less than $50.
____Less than $100.
_X___Less than $150.
____Less than $300.
____I have no limit.
____I’m flexible, tell me what you gotJ.
____Other, please specify ________
3) Format:
__X__I want a flashlight.
____I want a headlamp.
____I want a lantern.
____I want a dive light.
____I want a portable spotlight.
4) Flashlight-specific format/size:
____Keychain size.
____Every day carry small (2-4 inches).
____Every day carry medium (4-7 inches).
____Holster carry.
_X___Big enough to need its own travel caseJ.
____I don’t care.
____I don’t know.
____N/A
5) Emitter/Light source:
_X___LED (known for efficiency, longevity, and compactness)
_X?___HID (known for max output, but often at the expense of size)
____I don't know.
6) Manufacturer:
__x__I want to buy a light from a traditional mass producing manufacturer that is ready to go out of the box.
__X__I would consider getting a light that is pieced together (for example a “host” or flashlight body from one manufacturer, and a “drop-in” emitter from another source). Under the right circumstances, this path can provide more options to the consumer to meet specific needs, and can often be easily upgradeable as technology improves.
7) What battery type do you want to use?
____I intend to use alkaline batteries (AAA, AA, C, D) (disclaimer, while it does not preclude all choices, these are not recommended for many of today’s most powerful lights)
_X___I intend to use rechargeable nickel chemistry (NiCad, NiMH, NiZn)
__X__I intend to use lithium primary batteries (CR123, CR2, Energizer Advanced/Ultimate Lithium AA/AAA)
_X___I intend to use rechargeable lithium (li-ion) chemistry. Feel free to specify a size if you know which size you want (14500, RCR123/16340, 17500, 17670, 18650, etc.)
__X__I want a light with an integrated rechargeable battery. (Note: these choices may be very limited unless you are looking at spotlights)
8) How much genuine out the front (OTF) light do you want/need? Sometimes you can have too much light (trying to read up close up with a 100 lumen light is impossible).
____I want to navigate a dark room or read a map (0-10 lumens).
_X___I want to walk around an unlit rural area (50-150 lumens).
_X___I want to illuminate my entire backyard or a campsite (150-300 lumens).
_X___I want to illuminate an entire field, the neighbor's front yard several houses down, impress my friends and neighbors, etc. (300-700 lumens).
_X___I want ridiculous amounts of lumens (800+ lumens).
9) Throw vs. Flood: At what distance will you be most likely to use this light? Select all that apply.
____Less than 1 yard/meter (reading, other close work)
____Less than 5 yards/meters (looking for something inside a dark shed/garage/basement)
____5-20 yards/meters (check out a noise in the backyard)
_X___150+ yards (I want maximum throw possible)
10) Runtime: Not over-inflated manufacturer runtime claims, but usable brightness measured from first activation to 50% with new batteries (Measured on maximum output).
____30-60 minutes (I have plenty of batteries just ready to be changed)
____90-120 minutes (Runtime is moderately important, but still not critical)
_X___3 hours + (I critically need this light to run on max for extended periods in between battery changes/charges).
11) Durability/Usage: Generally the old phrase “you get what you pay for” is very accurate for flashlights.
____Not Important (A “night-stand” light).
X____Critical (Police, Fire, Search & Rescue, Caving, Survival).
____I don't care.
____I don’t know.
12) Switch Type and location (choose all that apply):
____I want a forward clicky (Helpful for momentary activation and signaling).
_X___I want a momentary switch (Predominantly for use with signaling and short bursts of momentary light only).
_x___I want a body mounted switch (near the head, like on a Maglite).
_x___I want a tail mounted switch (found on the majority of today’s high end lights).
____I don't care.
____I don’t know.
____A simple on-off with only one output level is fine for me.
X____I want multiple light levels. (Some lights have 5-16 light levels.)
____I want a selector ring.
____I want a strobe mode. (Blinks to show location.)
____I want SOS mode.
____I want a beacon mode.
____I don’t care.
____I don’t know.
14)Material/Finish/Coating
X____Anodized Aluminum – either type II or III (Hard Anodized) (Aluminum, specifically HA, is the most common material/finish for today’s flashlights).
_x___Stainless steel (durable, but much heavier than aluminum)
____Titanium (durable and nearly as lightweight as aluminum, but can be moderately to significantly more expensive).
____I don’t care.
____I don’t know.
15) Special Needs/extras: Is there anything else you want or need that hasn't been mentioned? Select any below.
____“Hybrid” light (bright incandescent combined with long running LEDs)
____Pocket/belt clip
____Holster
____Wrist/Neck Lanyard
____Crenulated bezel
____Non-sparking Intrinsically Safe (IS) for use in explosive environments
Ok after looking through this list I feel I need to better explain my reasoning and what I'm looking for. I want a full size light that I can use on traffic stops while working. I'd also like it to have multiple levels so I can use it to read paperwork etc on the side of the road and be able to light up a field or areas around a house. Because I live on a budget I'd like to keep it under $100 if I can. I'd like the possibility to recharge batteries and I want it full size about 12" long to use as a last resort defense if needed in a split second. Any suggestions? I was contemplating the Coast HP17 but I'm just not sure about it...
The 'new' streamlight SL 20L with 350 lumen, 60K candela LED is a good choice (aluminum body not the polymer). High, med, low, and strobe... And works with all the older chargers.... Not as heavy as the old SL 20 I had 18 years ago, but still can be used as a impact tool if you cannot transition to your baton. Average price 110 bucks.. Also no memory so it will default to high after being turned off
Well I was looking at that as a viable option just trying to see what else might be out there... But I appreciate the info. I saw the thread about the 1000 max lumen mag light mod that has the multi setting option. How hard would this be to do with a 3d mag? I've never done something that in depth with modifying but it doesn't look too difficult. Is it a better option to buy the parts and do myself?
The easiest would be to get a drop-in. Malkoff ones are the best from what I hear, but they require a bit more work then most. Single mode though.
For 1000+ out the front lumen, you'll need a bit more work then a normal maglite mod, and you'll end up with less throw.
Most of the lights here are small then the Maglites, some even fit comfortably inside the battery tube.
The Fenix TK41 (8 AA batteries) and TK60 (4D cells) could work for you.
:welcome:
The mod I was looking at was by jayrob and if I'm not mistaken I saw that he can do it to have multiple modes?
The modes are dependent on the driver used. If you have a 3D mag, there are a few drivers you can use. I modded my 3D a few months back with a driver with 8x AMC7135 chips, a Cree XM-L, and a Maglite heatsink. Illumination supply, Shiningbeam, and many other sites all have this driver and LEDs. The heatsinks you can find in the custom buy sell trade section.
The driver I used has 3 modes as well, but the modes are controlled by the same on/off switch, so signaling will cause the mode to switch. I'd prefer at least a driver with no memory.
The mode itself is fairly easy. A few cutting steps, a few solder points, and some application of thermal glue/paste.
Can you give specific links for the driver and led? Also what about using rechargeable a in a mag light?
From the banner at the top of the page
Linking to sales threads in the Dealer's Corner and Manufacturer's Corner at the MarketPlace is permitted in this forum. However links to Dealer's or Manufacturer's websites or other sellers outside of the CPF MarketPlace will NOT be permitted in this forum and such links stand to be removed by a moderator. Persistent violations of this policy may result in the loss of posting privileges.
Norm
