Alaric Darconville
(Probably not really a "transportation lighting" function since it's not even designed to produce lighting, but...)
Yes, that's right-- I'm looking for the automotive bulbs with the lowest luminous efficacy possible, because I have this silly, wacky, goofy, nutty idea to make a 12V automotive space heater that uses miniature bulbs for the heat (sorta like an EZ-Bake™ oven uses a 60W bulb to bake brownies). The bulbs will be semi-sealed up within an opaque container so there will be no light emitted (beyond what might leak out of edges or where the cord comes out).
I plan on using it in a 10A fused cigar lighter socket, so I figure I need to keep the total operating current below 10A so I don't pop the fuse every time I plug it in (even with a slo-blo fuse, inrush current on too many bulbs could trip it). Probably, then, it would be wiser to use fewer, but higher-wattage, bulbs than more, but lower-wattage, bulbs-- but I could also be wrong on that.
What bulb, due to its inefficiency, would give me the most BTU/hr?
