FlashlightKid
I was thinking that I would keep one of my Extreme III's set on P1 at the lowest setting. I believe this is 2% output, but i'm not sure on the lumen output at this setting (its super low, i'm guessing about one lumen). With it on this setting I was planning on keeping it on as a beacon/glow so I can find it easily and then switch it to P2 for more light. If it matters its also running a rebel emitter, not the newer SCC or Cree.
:candle:My question in whether this will have any negative effects on the LED's life and flashlight circutry.
:shrug:My thinking was that the current was so low that the LED would not be effected and the circitry should not be effected since the only ware item there is the EEPROM which would actually be written to less due to it not being turned off, thus saving the setting and performing one read write cycle.
I am not to concerned with recharging the batteries more often and if anyones interested I plan on posting my estimated runtimes (on lowest setting constant) if this ends up working out.
Thanks for your help, and hope to hear your responces.:thumbsup:
