krutzbeuazen
Hi!
(still) i plan to build a lamp/flashlight with many LEDs.
Since they are getting cheap, i thought about 100 or perhaps more LEDs. why not luxeon? would like 395nm N-UV.
okay.. how to power them.. nimh-cells seem to power them easily, up to 4A per AA cell. 4 or 8 of them should work nicely.
since the voltage drop on such high load will be quite strong, i need some kind of regulation (instead of resistors).
step-up-converter chips or whole circuits seem to be impossible to get over here in germany.
a voltage regulator would be really hard to build for 2, 3 or more Amp and would dim the output after minutes (as far as i know).
a current regulator would be possible to build, with a FET. nicest way so far.
(a big thank you to burnt_retinas for his hints on FET!)
problem with them is, if i hook several LEDs parallel to a constant current supply, some LEDs have slightly different specs, drain more power, heat up slightly more, lower their resistance, drain more power, burn. then the other LEDs get all the current for less LEDs, same thing happens, chainreaction, catastrophic failure of 100% of the LEDs in milliseconds. i guess the last few LEDs will almost explode, at 2A..
what to do? cant be that impossible to drive 100 LEDs with cells. portable. not necessarily in a nice small housing, but portable.
krutz, frustrated
krutz, frustrated
