Hey all,
I want to make an LED flashlight (luxeon rebel 4.5x3mm) that can produce an 80mm diameter beam from about 450cm away using a 20mm lens.
From what i've read, I can use a plano-convex lens to collimate light from a light source. If I use a 20mm lens, a perfect light point at the lens's focal length would produce a 20mm diameter beam correct? However, since it's not a point, the light would slightly diverge. I wanted to use that to my advantage to create a beam as mentioned above.
I read you can mess with the focal length as well as placing the LED in away from the focal length in order to produce a larger beam diameter at a certain distance away, but I couldn't figure out the calculations. I was wondering if anyone can help me figure this out.
Thanks so much!
Thanks so much!
