LED Head for Scorpion?
CalgaryGuy
Alberta, Canada
I know that the KL1 head will fit on a Scorpion but I want something brighter. Does the KL3 fit on a Scorpion? What about home made head? Anyone made one that can be put on a Scorpion?
If the KL1 fits, the KL4 should also fit. I hadn't heard that the KL1 fit though!
Neg, the Scorpion is a 2x123 xenon flashlight from Streamlight.
As far as I remember the KL1, KL4, McLux and just about anything that works on the E series bodies will work on the Scorpion body. The KL3 will probably work with an E2C adapter.
The KL3 with E2C "CAN" be brighter. It just needs to be modified and can accomodate a PR making it a throwing beast. In stock form, I'd stick with the KL1 as opposed to the KL3.
Ok,
Cheaper donor bodies. SL donating their bodies to science. This is a very noble cause, a match made in /ubbthreads/images/graemlins/evilgrin07.gif? Cheaper than an E series body but no option of a Z57 (my fav. add on). Hmm hmm.... /ubbthreads/images/graemlins/thinking.gif
If I remember correctly, is it guarded in a sense. I don't think it would stand on end though.
The tail switch is inside the rubber cover, and it will stand on end if you carefully balance it, at least mine will balance, although it is a little wobbly.
