LED lenser P14 disassembly?
capt. crunch
Hi all, first time post here.
I'm just wondering if anyone could point me in the right direction with regards to disassembling a LED lenser P14? Specifically removing the metal heat sink piece with the LED from the tube section. Is it press fit, tacked in or threaded?
I found a mod on this forum posted a few years back regarding replacing a resistor in the LED base mount and it seems like the tip of the mount is shaped to take a small spanner head but obviously I don't want to try and pull it apart if it is press fit and not threaded. I'd like to replace the resistor to improve the output as per the modification I found.
Cheers.
svocos
Sorry to necro an old thread.
Did you have any luck with this? I am thinking of modding my own P14 and wanted to know if this kind of mod was worth it.
