Hello,
I want to ask for help - advice because I don't understand anything from optics.
The situation is as follows: it is necessary to create a LED spotlight that will illuminate the object about 50x50Cm in size, the object from the source is located at a distance of 20m, led matrix size 40x40mm.
I tried to assemble a complex from fresnel lenses but nothing works, as I realized I bought the wrong lenses or frenel doesn't want to work in a complex.
I ordered these lenses : https://www.aliexpress.com/item/328...c99f1987703ba16f7-1594225931579-05524-_sSETun
with focal length 40mm; 60mm, 80mm.
Can anyone suggest anything, I don't need higher math calculations, it would be enough to tell how many lenses need to be in the complex to achieve the desired result, what lenses to use and where to put them.
Thanks.
Thanks.
