[ QUOTE ]
jtr1962 said:
[ QUOTE ]
NewBie said:
Unfortunately, alot of cities went with the bottom dollar bids from folks using LEDs from HK and similar areas, and that or other parts of designs fail very early, in some cases resulting in an average lifetime of six months to failure.
[/ QUOTE ]
I'd say the problem stems more from the circuit driving the LEDs than from the LEDs themselves. I've been using those "cheap" HK LEDs you speak of and I'm quite satisfied as to their brightness and quality. The only thing cheap about them is the price, which is good because at $1.50 each or more Nichias are quite frankly a ripoff. The key with LEDs (or any electronics) is to have adequate surge and spike protection. Sadly, many of the current LED traffic light designs were made by people used to working with incandescents. As a result, they're lacking in the protection department. Also, a simple resistored setup is not the way to go. You need at least filtering and current limiting.
[/ QUOTE ]
Actually, the Nichias get cheaper in volume, at 0.43 ea for whites, and cheaper in other colors. Though if I was doing colors, I'd highly consider Toyoda-Gosei.
Also jtr1962, are your HK LEDs exposed directly to the weather...?
BTW, someone is using some sort of different setup on some around here, my wife pointed out single LED failures to me one day, and we have seen green traffic lights with up to five random dead LEDs. Either they are individually driven, shorting out individually, or there is a bypass diode that turns on when the LED is out...
