Re: LED vs incandescent
It appears (and I may well be wrong, here) that LEDs are more efficient in turning watts into lumens... I've read that with LEDs heat is a byproduct of light while with incans, light is a byproduct of heat.
Should I draw the conclusion from this that an LED of a given physical size is likely to be brighter than an incan of the same size?
And while we're at it, let me ask about modifying LEDs and incans.... which are easier to modify and which offer the best results in response to available modifications?
If anyone is kind enough to answer this, whether agreeing or disagreeing, could you give me one or more examples?
Would I get the same or different answers from the incan forum..... should I post the same question there?
For the same amount of power you give to an LED or Incan, an LED will always produce more light, as they are more efficient.
That doesn't mean that for the same size, an LED will be brighter. LEDs generally have a maximum amperage you can give them, and for flashlight purposes, the best example of that would be the SST-90 which has a maximum of ~9Amps. And because LEDs are very sensitive to heat, they require sufficient heatsinking or they may be damaged.
There are halogen bulbs which can be driven much harder than that, so assuming you can fit a high-power source into a given flashlight, you can drive them very hard.
An example of this may be an SST-90 Maglight2D sized light producing ~2000 lumens, while you could fit an Osram 64623 bulb into the same Mag2D producing ~4000 lumens. (Although perhaps a triple SST-90......)
But as mentioned earlier, the power consumption of the incan will always be higher, and this will result in very short runtime (normally on the order of minutes in the previous example)
And so, if you're limiting yourself to say, a 1x16340 size light, then your power source is limited, and you'll probably get a brighter LED than an incan for that size.
Modding is both the same - there are easy mods for incans, and easy mods for LEDs, and difficult ones for both. I would say that incans are generally easier to mod at the beginner level as they're easy to Direct Drive (which IS possible for LEDs, just normally a bit more complicated) and you dont' have to worry much about heatsinking. If you go into regulated drivers, both have their challenges which others can probably attest to better than I can.
Both have their advantages and disadvantages.
You may get biased views in either forums, but I personally like both LEDs and Incans and that's my view.
