Legend 2AA "mini" mod?
StoneDog
Suwanee, GA
Legend 2AA \"mini\" mod?
Has anyone shortened a Legend 2AA to 1AA size? I know it's possible with mini-m@gs... Does anyone know if taps are available that match the Legend clickie's threads?
Jon
Re: Legend 2AA
i'm sure you can get a tap for the legend tailcap /ubbthreads/images/graemlins/icon3.gif
it would also be possible to use a kroll tailswitch, which i prefer anyway.
Re: Legend 2AA
Why does everyone like the Kroll so much? There's no way to lock it out, is there?
Jon
Re: Legend 2AA
no need to lock it out, the rubber boot does the job nicely /ubbthreads/images/graemlins/grin.gif
the only gripe is its unreliability (solved somehow) and its black colored boots that sometimes cannot match with the various MM color
Re: Legend 2AA
twisting the legend head down should brake the ground connection...
i've just found the legend tailcaps to be...icky.
Re: Legend 2AA
I like krolls better also, the legend tailcaps feel cheap. /ubbthreads/images/graemlins/icon3.gif
Re: Legend 2AA
Roth,
I agree that the Legend tailcaps aren't ideal, that was my (only!!!!) complaint with the micro-illuminator.
I plan to put a MM+ R2H into a Legend 2AA or 1AA and was hoping to carefully drill out the stock reflector enough fit the LS inside. If it will give similar results to the micro-illuminator it should make for a nice EDC. But, I don't want to rely on the reflector pushing on the LS to break the connection to ground (to effect a lock-out function), which is why the Legend's lock-out clickie must be kept.
Besides, aren't the Mags (and therefore Krolls) threaded differently than the Legends? I didn't think the Kroll would even work...
Jon
Re: Legend 2AA
yes, the threading is different, but once you chop the back end off, you can rethread it however you want /ubbthreads/images/graemlins/wink.gif
Re: Legend 2AA
Ahh, I see. /ubbthreads/images/graemlins/smile.gif
Well, maybe I'll just stick with the standard 2AA configuration for now. Thanks for your help.
Jon
