if you want as much light as possible, use Anti Reflection (AR) coated materials. These are more expensive though, and I doubt you would see the difference.
when not using AR coated materials, glass and transparent plastics are more or less comparable.
For scratch resistance, I think glass works better than acrylic, PMMA or PC, but is more difficult to work with (cut/grind).
There are also different types of lexan, each with sometimes very different properties. At work we had some samples, Lexan MARGARD was best for scratch resistance, but I think that is a brand name, not a real name of a certain material.
If you really want to get the best material, you better contact a supplier of such materials. They should have spec sheets and should be able to tell you what material is best for the purpose.
Johan
