LF3XT-something aint right
sigsour
Franklinton, NC
I was trying to reprogram my light from 5 brightness modes to 3 modes.....now I have ended up with 2 brightness modes and I cant do a 4c + PH nor can I do a 3c + PH. When I turn the light off and then turn it on again, it goes to the brightest setting and I am able to 2C it and lower the light level until I turn the light off again....it goes back to 2 modes High and Low. My light doesnt blink or anything. Can I do a reset somehow? I am stuck here. Any help would be appreciated.
Does anything happen when you 5c + PH to change UI?
How about 4c to go to tactical?
If you 5c does it give the battery voltage report?
I am only asking these to see if ANY of the normal functions are present.
Also, are you using Budman231's flowchart for a reference or the manual?
I hope this is just a hiccough with your programming I never had a problem with either light. :confused:
Cheers Norm
It was definitely an IO error and not the light Norm. :twothumbs
I love the light....just need to mess with the programming a little more.
