Kindly donated to me a few weeks back by Elektrolumens, I tried this white 1-watt Lambertian High Dome Luxeon with both new optics and old optics and was unsatisfied with the results, as it was pretty much duplicating what I had found with an earlier Lambertian, also from Wayne.
And then as I was assembling the run of 1-watt LGI Shorties it dawned on me that I might want to try the High Dome with the larger reflector of the Legend LX -- and so I did. Here it is sitting on top of an LX:
And here it is nestled down inside the cutout of the LX's aluminum reflector:
So I then put it up against a couple of similar 1-watt Luxeon lights, the Tuxedo and the Arc-SLS:
And finally the beamshots:
Notice how tight and bright the LX's reflector focuses the blue-white beam, and how intense it appears compared to the diffused beams of the other two.
So we sallied forth on to light meter testing:
Arc -- 247 lux
Tuxedo -- 352 lux
High Dome Shorty -- 561 lux
The Lambertian finally finds a home...and it's focusable.
Arc -- 247 lux
Tuxedo -- 352 lux
