depusm12
I did a run time test on a few of the different Li-Ion batteries I have.
Batteries tested include CR123 900 mAh Tenergy , AW 17670 1600 mAh, UltraFire 17670 1800 mAh. The light used was a Insight HX2 Typhoon w Seoul P4 led. Tenergy 900 mAh CR123 ran for 1hr 7 minutes before the light started blinking (indicating a low battery) and finally shut off. Note: On the 17670 batteries the low battery light will blink due to the fact it only has 3.7 volts/vers the 6 volts it requires from the CR123's. The AW 17670 1600 mAh ran for 1hr 15 minutes before I terminated the test. Light was warm to the touch. The Ultrafire 17670 1800 mAh also ran for 1 hr 15 minutes before I terminated the test.
