45/70
As my Li-Ion cell collection increases in size, so do the different types. What is the best way to determine the approximate state of charge of:
1. 3.0 Volt LiCo Li-Ion cells.
These are normal LiCo cells with diodes incorporated that in effect, reduce the voltage from 4.2 to about 3.2 Volts under load.
When I measure the OC voltage of this type cell, I often can get 3 different voltages. I'm assuming they are, the cell w/o diodes, the cell with 1 diode, and the cell with both diodes. Is there an easier way to get a more accurate/dependable voltage reading of this type cell?
2. LiFe/A123 Li-Ion cells.
Detemining the SOC of these cells by reading the OC voltage seems likely not to work, as the voltage stays relatively flat throughout the discharge, as compared to LiCo cells. Can it be done, or is there no relationship between voltage and SOC in LiFe cells, similar to CR-123A primaries?
3. LiMn/IMR Li-Ion cells.
I don't have any of these......yet. Is the SOC determined in the same manner as for LiCo's, or?
4. What's the best flashlight? What's the best torch? Which came first, the chicken, or the egg? I'm the 999,999,999th visitor, did I win?
:oops: Sorry, scratch #4, wrong forum. My apologies, DM51. :D
Dave
Dave
