belomeclone
- Joined
- Oct 13, 2009
- Messages
- 212
Is it safe? If I drop my keys, is it safe? Just... safety in general!
I carry a ITP A1 with a 16340 li-ion all day every day. Never had a problem. Always use protected cells so if the light accidently turns on in your pocket the pcb should kick off the battery before its drained to low. They also trip off if the current gets to high. Giving you some protection.
16340 is a li-ion in a cr123a size. Although not the same voltage. The Itp A1 can use either one. 16340 li-ion is 16mm diameter by 34mm high.16340, I'm unfamiliar with them. I thought 10440 was the only size li-ion for AAA batteries, and that they couldn't be protected.
Yes, the protection circuit will trip under a load some where around 2.75v. The resting voltage once the pcb has been triped should be around 3.25v or higher. Left in this state I have read, the battery can have irreversible damage. If the protection trips charge the battery up to at least 40% 3.8v at rest as soon as possible. The battery shouldn't suffer any ill effects from this if not left in a low state to long.And I thought the protection saved your unit but ruined the battery. It can help save the battery for future use too?
