KrisP
Hi,
I have the Swallow 2 Advance charger which is apparently the same as some other brand of chargers, anyway when you choose Li-ion in the menu it says 3.6v and when you choose Li-Po it says 3.7v. All my li-ion cells clearly say 3.7v on them, so i'm unsure what setting I should be using. I've been using the Li-ion setting to be on the safe side, but it only charges the cells to 4.1v. The instructions also say that the Li-ion setting will charge to 4.1v and the Li-Po setting will charge to 4.2v.
What are others doing with their charger like this?
Thanks,
Kris.
Thanks,
Kris.
