I've just bought a second hand hope vision HID battery (14.8v, 2400mah), mainly for the casing, but also to turn into a 7.2v 4800mah battery for my hope vision 2 light. I've got it apart and have a question about rewiring it. At the moment the 4x 18650 cells are configured in 2 blocks of two, each connected to its own pcb (Giving 2 sides of 7.2V 2400mah). The two pcbs are then connected is series neg -> pos by a small resistor to give 14.8v across the whole lot.
Now to rewire this do I need to
a) Split the two pcbs at the resistor and wire the two sides in parralell
b) Wire the batteries in series so they form 2x 3.6V 4800mah pairs and connect both pairs to one of the pcbs pcb as if they were a single cell?
If that's not very clear I'll do some wiring diagrams to explain more.
