Light for firefighter/general use
colonel70
Hey. Im new to the forum. I have been lurking for a few days now and have finally decided to join up!
Being a firefighter and working in ever changing conditions where lives/property may hang in the balance id like my equipment to work every time.
I dont feel like my criteria is too limiting to lights based on the previous research I have done.
Id like a light that I could use on fire scenes/wreck-rescue scenes as well as to use as a general purpose light. I already have a light that I EDC so this wont necessarily have to be compact. This light will be carried in my EDC bag more than likely until it is called to duty.
I am looking heavily at the Fenix PD35, TK15 and i am also looking at the 4Sevens Quark and Malestrom series lights.
With that being said I have completed the check list . Feel free to make suggestions and criticisms as well as ask me questions.
Doesnt matter whether its online or B&M.
2) Budget: An easy question, but you may change your mind after answering the rest! :-)
Up to 100.
Not opposed to go slightly over (read 10-15 over) so long as the light will perform that much better. Obviously lower the better
:D
3) Format:
I want a flashlight.
4) Size:
Doesnt matter. I would like the ergos to be suited to use anywhere between plain vision bare handed all the way to limited visibility with fire gloves.
5) Emitter/Light source:
Doesnt matter, however, I prefer LED due to run times and performance.
6) Manufacturer:
Doesnt matter so long as the customer service is good.
Doesnt matter but i prefer the option of rechargeable
This probably matters the least of all features as to how it charges.
I want a multitude of options. I want a lower lumen mode to look for things inside a vehicle/house all the way to a higher output light in the event of a search and rescue situation.
I would prefer the options of strobe/SOS (maybe others as well), however, this isnt totally necessary.
____Wide Throw: I want a beam with a noticeable hot-center for distance throw and a significant amount of "side-spill". Good for rough trail hiking, search and rescue, and general distance work.
I believe wide throw would be my best bet. I want to be able to reach out a bit with the throw but id like a decent amount of side spill.
____Less than 5 yards/meters (looking for something inside a dark shed/garage/basement)
____5-20 yards/meters (check out a noise in the backyard)
Id say somewhere between these 2 (yet closer to 5 yards) would be 95% of the lights usage, but, again id like some reach in the event of a search and rescue.
____90-120 minutes (Runtime is moderately important, but still not critical)
A long runtime would be preferable. I plan on buying (or making) a traffic wand attachment for the light so a moderate brightness setting that would run for a few hours would be very nice.
11) Durability/Usage: Generally the old phrase “you get what you pay for” is very accurate for flashlights.
____Critical (Police, Fire, Search & Rescue, Caving, Survival).
Switch size isnt too important so long as i can activate it with a hand covered with a fire glove.
Type and location doesnt matter too much.
***I do like the fenix style UI with the dual switches. I also like 4Sevens style of switching too.
Multiple levels, strobe/sos/beacon are definitely preferable.
Programmable would be cool but definitely isnt a deal breaker.
14)Material/Finish/Coating
Not very important as long as it is DURABLE. Would prefer scratch resistant lenses.
15) Water resistance
IPX8 prefered. A lower standard may work.
16) Storage conditions
Storage conditions are ever changing. Think Kentucky climates.
____Non-sparking, Intrinsically Safe (IS) for use in explosive environments
This is important to meEDIT: Preferred but not required nor is it a deal breaker.
A lanyard attachment, holster, and crenulated bezel could be nice but not necessary.
Being a firefighter myself, the,best light I've found was the streamlight strion series. Has awesome run time, recharges in 2.5 hours and with the lithium battery it was safe to bring in house fires. Mine saw lots of helmet use. Good light, love it so much I own 4 of them. Also the stinger ds LEDs are the same light in a bigger package with a little more throw.
Thanks for the reply Fast LT1!
I am pretty familiar with the Streamlight line (C4 survivor, Vantage, etc etc) but am not familiar with the Strion. To be honest i hadnt even considered Streamlight lately (lapse of judgement mostly). Ill have to look into them a little further.
I now realize that my original post was jumbled and poorly formatted so ill see if i can shorten it to a simple list.
-Looking for a flashlight that will be at least near my person at all times. Will be EDC bag kept until it is needed. The light should be able to survive the (sometimes) harsh environments of firefighting.
-Need multiple brightness levels including:
*Low for searching for things around the house/vehicle
*Medium setting for things like directing traffic and general outdoor duties
*High for The occasional search and rescue applications
*Turbo style mode preferred but not required
*Multiple special modes (Strobe/SOS/Beacon) also preferred but not required.
-Ergonomics arent very specific so long as i can activate it bare handed all the way to a heavy gloved hand.
-User Interface isnt too specific either as long as it has multiple brightness levels.
-Battery source doesnt matter, however, i would prefer a removable/rechargeable option.
-Runtime in a medium brightness setting should be a decent time for traffic direction situations (anywhere between 30 minutes to 3 hours)
-Seems like a wide throw would be a good happy medium for my purposes. The majority of the use would necessitate a flood (think 5-10 yards) but i would like a light capable of reaching out fairly far (60-100 yards+) considering i have a decent flood style light in my possession already.
-IPX8 preferable but not an absolute requirement.
