exceedspeedby10
- Joined
- Sep 29, 2011
- Messages
- 19
Gday all,
I'm in need of a light where you are able to change the diameter of the beam, and also (not vital tho) the brightness. Weight is not an issue. If rechargable, battery life must exceed 4 hours. It also has to be very, very bright. I was thinking about making a HID rig, but zoomability, output adjustment and excessive heat generation are all going to be problems. LEDs would most likely be (?) a better choice, but my budget is severly limited, a couple hundred at most.
Is there any way to zoom the beam of HID light sources? If I made my own, maybe adjust the reflector with screws, or use a material to gradually block off the light or something?
I havent much of a clue when it comes to portable light sources beyond ones that just flash, so I was hoping for a few thoughts from a community that seems to know a thing or two.
cheers guys, Tom
cheers guys, Tom
