Klem
A 40Watt light sabre, designed to take on Darth Vader.
Thought I'd push the envelope with what is available, to see what is possible. Happy to share the pros and cons of this design.
It's a hand-held PVC canister same diameter as a Maglite head, 56mm.
4*XM-L T6's at max current 3A, 1000lumens/LED. On paper the highest setting is 4000lumens. Forward voltage for an XM-L at 3A is 3.35V, so 13.4V for 4 LEDs in series, plus another volt for the driver and it comes in 14.5V... just under the cut-off voltage of the battery pack, 15V.
Uses the same reflector as the DX 5*XR-E drop-in. Heat sink is a 2cm machined aluminium plug that is a tight press fit with the sides.
Driver is a H6Flex from TaskLED running in trimode...3 settings; 8W, 21W and 42W. Battery cut-off is set at 15volts. Battery warning at 16V. 90Watt/hr battery should give 2 hours on High, 4 hours on medium, and 8 hours on Low. Haven't tested to exhaustion yet and I doubt whether the trustfire batteries are really 2.5Ah.
Two switches trialed...A Hall effect with magnet (TaskLED), and twin stainless bolts on the base for tapping against a conducting surface.
Canister is made from 50mm PVC plumbing pipe. No threads...press fit with O ring (so no twisting of cables).
18V Li-ion Battery made from 10*18650's in a pentagon shape. 5S2P configuration gives <5Ah. 21V fully charged is the max voltage a H6Flex can take. Joining cables run up the middle hollow. No battery PCB needed as the monitoring and cut-off is performed by the driver. XT60 main and JST balance plugs. Extra plug for bolt switching.
Lens is 6mm Perspex glued permanently to the bezel with marine putty. The bezel is waterproofed to the head with Silastic...in case you need to crack it open for servicing.
This requires time on a lathe. Machining of the Maglite head: Get rid of the inside threads, make the inside ledge deeper, machine the outside to go into a pipe and the O-ring groove. The heat-sink plug is 23mm long with a 3mm rim. Hole drilled through and then Dremel a surface chanel under the driver for the wires to come around. O ring is 48*2.5mm
Main plug is an XT60 (60amp rated). Thought I'd try a better plug than the Dean's and it pulls apart like a dream. Bit bigger than a
Dean's plug but worth it.
Head is waterproofed by potting the back with polyeurathane. If the canister leaks the head will be OK.
Two stainless bolts on the base for the second switch. Tap against a metallic conducting surface.
I'm thinking either the armband or attach a hose-clamp and use a lanyard. Lanyard can be part stainless trace for closing the base contacts underwater, or have a magnet on the inside of tubular climbing tape for the Hall switch. I figure if you can open your hand 30mm to hold a Maglite you can open it 56mm, and so be able to have the batteries needed for the high power draw. Fits in a BC pocket.
Comparison with the Ugly Light' on the left, and a 2D on the right. 23cm long, 940grams above water. 360gms below water (negatively buoyant).
Beamshot comparison between the XR-E DX drop-in and the Obiwan Kenobi. Same settings for the camera, both 1 metre from the wall.
'No bubbles, no troubles'
Thoughts;
It's bright, but a lot of it goes into spill. That reflector is not designed to focus an XM-L.
Gets hot very quickly and this will only work underwater. Above water would cook within a couple of minutes on high. Even underwater extended use on High has it noticeably warm to the touch.
Probably work just as well with 3 XM-L's (DX has a similar reflector for 3 LEDs).
That DX drop-in is just as bright when comparing the centre hot-spot. The advantage of the Yoda sabre is a wider beam.
The O ringed press join between the head and body works fine. Takes a bit of work to get on/off but that means it's not coming apart at 40metres.
Clean lines, so as not to hook up on anything.
Canister needs a lick of paint to pretty it up.
If this works out then the next one will be all metal, with head machined out of a solid rod and using the Barantec prolonged contact piezo switch. Need a longer than normal piezo to be able to give both 'clicks' and 'presses' to work the driver..
May the force be with you!:candle:
Thoughts;
