Lightweight Backpacking hat-brim-clippable light
e.soul
Hello All! I've recently stumbled into the world of modern LED flashlights and I think I'm hooked! I'm looking for the perfect light to take backpacking. So far, the best thing I've found is the Fenix E11. I purchased this light recently, and I find the "low" (35 lumen) setting to be just about right. I like the fact that it's so lightweight and that it will run on this setting for 8 hours. My plan is to use it as a headlamp by clipping it to the brim of my hat. I have a mag lite clip on order that I'm hoping will fit the E11.
I'm happy with the E11, but I would like to know what other options are out there. My main requirements are:
- lightweight (1.7 oz or less including the battery)
- a useable medium or low setting of around 35 lumens with several hours of runtime
I'd like to find something with a clip included and maybe 3 or more modes (the addition of a true "low" 3 lumen setting would be nice for example).
I've included my answers to the standard questions below. Thanks in advance!
____I will be mail-ordering or buying online, so this doesn't matter.
2) Budget: An easy question, but you may change your mind after answering the rest! :-)
____Less than $50.
3) Format:
____I want a flashlight.
4) Flashlight-specific format/size:
____Every day carry small (2-4 inches).
5) Emitter/Light source:
____LED (known for efficiency, longevity, and compactness)
6) Manufacturer:
____I want to buy a light from a traditional mass producing manufacturer that is ready to go out of the box.
____I would consider getting a light that is pieced together (for example a “host” or flashlight body from one manufacturer, and a “drop-in” emitter from another source). Under the right circumstances, this path can provide more options to the consumer to meet specific needs, and can often be easily upgradeable as technology improves.
7) What battery type do you want to use?
____I intend to use lithium primary batteries (CR123, CR2, Energizer Advanced/Ultimate Lithium AA/AAA)
8) How much genuine out the front (OTF) light do you want/need? Sometimes you can have too much light (trying to read up close up with a 100 lumen light is impossible).
____I want to navigate a dark room or read a map (0-10 lumens).
____I want to walk around an unlit rural area (50-150 lumens).
9) Throw vs. Flood: At what distance will you be most likely to use this light? Select all that apply.
____Less than 1 yard/meter (reading, other close work)
____Less than 5 yards/meters (looking for something inside a dark shed/garage/basement)
____5-20 yards/meters (check out a noise in the backyard)
10) Runtime: Not over-inflated manufacturer runtime claims, but usable brightness measured from first activation to 50% with new batteries (Measured on maximum output).
____3 hours + (I critically need this light to run on max for extended periods in between battery changes/charges).
11) Durability/Usage: Generally the old phrase “you get what you pay for” is very accurate for flashlights.
12) Switch Type and location (choose all that apply):
____I don't care.
____I want multiple light levels. (Some lights have 5-16 light levels.)
14)Material/Finish/Coating
____Anodized Aluminum – either type II or III (Hard Anodized) (Aluminum, specifically HA, is the most common material/finish for today’s flashlights).
15) Special Needs/extras: Is there anything else you want or need that hasn't been mentioned? Select any below.
____Pocket/belt clip
Quick Update:
I stumbled upon the Foursevens Mini MA light last night. This looks just about perfect if I can find a clip for it.
L3 illumination's L10 and pocket clip from SB flashlights. Not sure on long term durability as they are fairly new but they seem to be good, especially when you take price into account. Come in 3 or 4 mode models. Im very happy with mine.
As you've probably already figured out, the Mini's beacon mode is one of the biggest features of these lights. If you have to wander off very far from your tent at night, leaving this flashlight hanging inside it on low beacon will give you a visual you can spot from quite a distance. This of course assumes you've got more than one flashlight, but if you're out backpacking, I figure three lights of some kind is the bare minimum. I carry the MLR2 with me at all times and it works perfectly as a cap light (with either of the clip mods I show in the thread mentioned above). The MA ought to work equally as well and is even better for backpacking because of the battery type (as you've also probably already figured out). On any overnighter, I'd probably have the MLR2, the MA, plus a larger light that also uses aa batts, i.e., an EA4 or a comparable Eagletac.
