n4zou
I have read about how hot the P7 gets when driven to full output so I'm considering liquid cooling. Should be simple enough. Just solder 1/4" copper tube to the copper sheet metal heat sink. I don't want to use a pump to move the coolant around. I think just having a small copper tank with cooling fins like a standard heat sink using the natural rising flow of heat would do it. Of course the tank would be mounted above the LED. Thoughts and comments?
