Longbow ECO, Twistcap, 2 Year Review
Badmovies
The original thread I posted shortly after receiving my Longbow ECO is here:
http://www.candlepowerforums.com/vb/showthread.php?t=72721
I have been using this flashlight for over two years. If memory serves, I paid about $90 for it at the time.
It has been in a pouch on my hip (along with a multi-tool) almost every day since I purchased it. The flashlight is used on a weekly basis at the very least. If I am using it often, I will switch out the batteries and put a freshly set of charged NIMH AA batteries into it about once every three days. Otherwise, I often swap out the batteries about every two weeks.
The ability to use rechargeable NIMH AA batteries is a big plus, especially if you are deployed. I kept two pairs of batteries with me in Iraq. I had a small Iraqi to US power converter and a little 4 AA charger. Before going to sleep I would swap out the batteries every night.
The beam is a good balance of spot and flood for general use and bright enough to be of use at night, even at a fair distance. It is not as bright as Surefires or other high output flashlights. The regulated runtime means that you can suddenly find yourself without juice. Something interesting I have found is that if you turn it off, then try to turn it back on and the batteries are low – just try turning it off and on a couple more times. Quite often, I will get the beam back and it will last another solid ten minutes.
The Longbow has been through a lot of abuse. In addition to all the normal whacks and smacks you might expect, I have struck it very hard against concrete after taking a tumble on a dark and rainy night when I was moving at a trot. When I fell, I slapped out with my left hand, the one holding the flashlight, to break the force of my fall. The Longbow hit the solid concrete with a lot of force. My hand, buffered from the concrete by the flashlight, was skinned raw in places and left tingling. The flashlight's finish was scratched and had small gouges, but otherwise it did not suffer any ill effects. I have done less to a mini Maglite and the internals were damaged.
There are a number of dings and scratches, most concentrated around the bezel. The outer lens (it has that and a thicker one that surrounds the LED) has a few nicks in it, but has survived without fracture.
It has been soaking wet, even submerged, a number of times, exposed to temperatures over 115 degrees and below zero and has not had any problems. The flashlight has also been exposed to fine and gritty sand for extended periods with no ill effects. As insurance, I did give it a good cleaning after returning from Iraq. The twisty cap still operates smoothly.
This is the first flashlight to survive two years with me, though my prior experience was entirely mini Maglites. Still, I believe that it is a well designed flashlight. To me, it is worth the price I paid.
Welcome back Badmovies, good to hear that the Longbow has survived two years of good service.
The bad news is that Longbow is gone (correct me if I'm wrong). But others have come to take its place.
But the good news is that there are New LEDs around that are twice as efficient as the Luxeon, Cree, Seoul and Edison. Great time to come back.
I was wondering if the company was still making flashlights after checking their website. That is a shame if they closed shop, because the Longbows are darn fine lights. I might have to get another one before they become hard to find.
Now I need to research another flashlight that meets the criteria and can use rechargeable AA batteries. Curses.
Nice followup, Badmovies.
I really appreciate nutz and boltz retrospectives on work lights. Thanks.
I was very interested in the ECOs back then, but, alas, I never bought one. Still, for me it's good to hear extended field reviews even if I don't have the light because there is always something to be learned from field experience.
Thanks again.
The Fenix L1D-CE and L2D-CE(Fenix Store) are the ones to get right now, six modes:
Loose Bezel(1/2 turn or less from full tightness): Low-Medium-High-SOS
Tight Bezel:Turbo-Strobe
But they have tint problems and the reverse clickie does not allow for momentary and only turns on when you let go of the clickie
Review(both), L1D-CE, L2D-CE, Longbow Micra(Simular?)
I hope that helped
Edit:added links
It sure would be nice to see a PICTURE! I like looking at well used flashlights. Too many shelf queens around these parts. It's great to see the Longbows held up so well, I never owned one but I think they were well designed.
It's too bad the Longbow company didn't last, IIR their plan was to offer consumer interchangable LED modules as technology advanced.
I don't think the Fenix models will have the longevity you saw from your Longbow. The light body rubs against the circuit board trace to make an electrical path for Max. Some people have already worn this out and can't get max to work consistently.
I say keep using the ECO for a while. The light to replace it with is the NovaTac /HDS EDC that might be released this year. They are planning to come out with a 2AA tube, but they will probably be hard to get. It has multiple modes is built like a tank and will be 4+ times as bright as the ECO. (and maybe only twice as expensive)
Nothing I have is ever a safe queen. If I purchase a piece of gear, it is going to get used. Can do on the picture of the Longbow and pouch:
I have looked at the Fenix and Inova flashlights, but they do not fit the criteria I have as well as the Longbow. The Longbow's size was perfect too.
HDS seems to make high quality lights, so if they put out a AA model I would probably get one.
I realize that CR123 batteries give a lot of bang for the buck, but NIMH AA batteries are a big asset - especially considering that over in Iraq we had problems getting batteries at all, let alone a less common size like CR123.
Flashlight bulbs or any sort of replacement part were pretty much impossible to get in Iraq (you could sometimes get Maglite bulbs). If you wanted it, you needed to write back home and ask for it. That meant a turnaround time of more than a month.
I remember seeing accessories for the Longbow on their website, such as LED modules with different color LEDs. You would unscrew the entire head off the flashlight and screw on the other one. They went modular with a lot of the parts. It was a great idea.
I agree, the longbows are really fine lights. Since the new seoul led has come out, there's an excellent option to upgrade them. Do a quick search for McCapsule to see what can be done with a longbow...
Chrisse
