... so I'm moving it there now.This will get more visibility in the batteries section of the forum
I tried some of the Energizer against the Philips Lithium cells and the Philips came out a little bit better in my very un-scientific test. Look up Philips Lithium Ultra on Google.
I have never seen an L91 ruin a device and I use them in all kind of devices. They have a nominal 1.5 volts.
Just a suggestion . . . .
If you DO include Alkaline batteries in your "kits",
simply make sure to store them separately.
Not inside any flashlight, or other device.
Keep 'em in Original Packaging, and you should be fine.
Certain model Petzl headlights carried warning labels against using 1.8v Lithiums.
" ... Petzl warns against the use of lithium batteries with this headlamp as doing so might cause the lamp to overheat and damage the LED bulbs."
Found at the bottom here:
http://www.rei.com/product/768981
L91's are 1.5 volts. http://data.energizer.com/PDFs/l91.pdf
You believe marketing materials?
Yes I do, I doubt many people know their batteries better than they do. Do you believe Petzl's marketing? They don't make LEDs.
But yah, no big deal. If you fry your Petzl because you used Lithiums, you just have to buy a new one. Good biz for Petzl. Good for you too since you get to buy a new light ;)
I think most people would prefer not to have something fry while it is attached to their head, so this could be a serious point.no big deal. If you fry your Petzl because you used Lithiums, you just have to buy a new one
