Looking for a bright flashlight around $200
  • Thread starter Thread starter z_weidmark
  • Start date Start date
Z
z_weidmark
Guest
Hey guys, hopefully im posting in the right area... there are lots of subthread and its pretty confusing. I am looking for a flashlight that can WOW the people I show it to. I was considering buying the Wicked Laser Torch (cool that it can light paper on fire) but I figured id ask here first before i went out to buy anything.
I also just saw the TActical HID 35w http://tacticalhid.info/hid-store can anyone tell me how much this light is?
I1) How would you prefer to purchase the light?
____I will be mail-ordering or buying online, so this doesn't matter.
2) Budget: An easy question, but you may change your mind after answering the rest! :-)
right around $200
3) Format:
____I want a flashlight.
4) Flashlight-specific format/size:
____I don’t care.
5) Emitter/Light source:
____I don't know.
6) Manufacturer:
____I want to buy a light from a traditional mass producing manufacturer that is ready to go out of the box.
7) What battery type do you want to use?
I would like to use 18650's if possible
8) How much genuine out the front (OTF) light do you want/need? Sometimes you can have too much light (trying to read up close up with a 100 lumen light is impossible).
____I want ridiculous amounts of lumens (800+ lumens).
9) Throw vs. Flood: At what distance will you be most likely to use this light? Select all that apply.
____150+ yards (I want maximum throw possible)
10) Runtime: Not over-inflated manufacturer runtime claims, but usable brightness measured from first activation to 50% with new batteries (Measured on maximum output).
Doesn't matter too much to me
11) Durability/Usage: Generally the old phrase “you get what you pay for” is very accurate for flashlights.
____I don’t know.
12) Switch Type and location (choose all that apply):
____I don't care.
____I don’t care.
14)Material/Finish/Coating
____Anodized Aluminum – either type II or III (Hard Anodized) (Aluminum, specifically HA, is the most common material/finish for today’s flashlights).
15) Special Needs/extras: Is there anything else you want or need that hasn't been mentioned? Select any below.
Nope
Thanks,
Andrew
