Looking for a EDC clip light
phobiarg
____I will be mail-ordering or buying online, so this doesn't matter.
2) Budget: An easy question, but you may change your mind after answering the rest! :-)
____I’m flexible, tell me what you got.
3) Format:
____I want a flashlight.
4) Flashlight-specific format/size:
____Every day carry small (2-4 inches).
____Every day carry medium (4-7 inches).
5) Emitter/Light source:
____LED (known for efficiency, longevity, and compactness)
6) Manufacturer:
____I want to buy a light from a traditional mass producing manufacturer that is ready to go out of the box.
7) What battery type do you want to use?
I want to use AA batteries
8) How much genuine out the front (OTF) light do you want/need? Sometimes you can have too much light (trying to read up close up with a 100 lumen light is impossible).
____I want to navigate a dark room or read a map (0-10 lumens).
____I want to walk around an unlit rural area (50-150 lumens).
____I want to illuminate my entire backyard or a campsite (150-300 lumens).
9) Throw vs. Flood: At what distance will you be most likely to use this light? Select all that apply.
____Less than 1 yard/meter (reading, other close work)
____Less than 5 yards/meters (looking for something inside a dark shed/garage/basement)
____5-20 yards/meters (check out a noise in the backyard)
____150+ yards (I want maximum throw possible)
10) Runtime: Not over-inflated manufacturer runtime claims, but usable brightness measured from first activation to 50% with new batteries (Measured on maximum output).
____90-120 minutes (Runtime is moderately important, but still not critical)
____3 hours + (I critically need this light to run on max for extended periods in between battery changes/charges).
11) Durability/Usage: Generally the old phrase “you get what you pay for” is very accurate for flashlights.
____Critical (Police, Fire, Search & Rescue, Caving, Survival). (military)
12) Switch Type and location (choose all that apply):
____I don't care.
____I don’t know.
14)Material/Finish/Coating
____I don’t care.
15) Special Needs/extras: Is there anything else you want or need that hasn't been mentioned? Select any below.
____Pocket/belt clip
Leaning towards the Quark AA2 Tactical. I hear the Fenix diffusers fit on them so I can get my red light that way.
I recommed the Jetbeam RRT-0 it has 5 settings, you have the option to use extender to use a AA battery. The Surefire E series filters fit. Here is mine with the Nitecore D10 clip I modded to fit. The diffuser is an Arrowhead water bottle cap (free).
A Quark would be a good choice. The 2AA Turbo will give you the most throw but has a larger head that is not the best for edc. The RRT-0 is a great edc (I edc one daily) and does run on 1 AA with the extender, but to get the most light from it, it really needs to be run on lithiums (either a primary CR123 or rechargeable Li-ion RCR123 or 14500.)
Ended up with the Quark AA2 Tactical, I watched a few videos about it and love the interface with the 2 setting memory mode. I couldn't justify the $100 for the jetfire when the Quark is $40 less.
The quark AA2 is meant to be a very good light, and from the all the positive reviews I've read, I doubt thats not the case. You should snap some pics when it arrives.
The more I see the jetbeam rrt0 the more I want one, just looks like a really nice EDC light.
