bassopotamus
- Joined
- Jul 10, 2013
- Messages
- 17
I'm looking for a light for Deer/Hog hunting (I am fully aware that deer hunting is not allowed by flashlight, but tracking blood trails is, and pretty much all bets are off when it comes to hogs). I've got the questionnaire below, but one consideration is that I'd like something that could possibly be mounted on a Remington 700/Model 7 (seems like most mounting brackets are for AR styles, but I see there is a magnetic). I don't know much about flashlights (I have a little Olight on my keychain) so feel free to correct any of the choices I've made below. Thanks in advance
____I would like to purchase the light from a brick and mortar store. I am located in ______________.
_x_I will be mail-ordering or buying online, so this doesn't matter.
2) Budget: An easy question, but you may change your mind after answering the rest! :-)
____Less than $25.
____Less than $50.
____Less than $100.
_x_Less than $150.
____Less than $300.
____I have no limit.
____I’m flexible, tell me what you gotJ.
____Other, please specify ________
3) Format:
_x__I want a flashlight.
____I want a headlamp.
____I want a lantern.
____I want a dive light.
____I want a portable spotlight.
4) Flashlight-specific format/size:
____Keychain size.
_x__Every day carry small (2-4 inches).
_x__Every day carry medium (4-7 inches).
____Holster carry.
____Big enough to need its own travel caseJ.
____I don’t care.
____I don’t know.
____N/A
5) Emitter/Light source:
_x_LED (known for efficiency, longevity, and compactness)
____I don't know.
6) Manufacturer:
_x__I want to buy a light from a traditional mass producing manufacturer that is ready to go out of the box.
____I would consider getting a light that is pieced together (for example a “host” or flashlight body from one manufacturer, and a “drop-in” emitter from another source). Under the right circumstances, this path can provide more options to the consumer to meet specific needs, and can often be easily upgradeable as technology improves.
7) What battery type do you want to use?
_x__I intend to use alkaline batteries (AAA, AA, C, D) (disclaimer, while it does not preclude all choices, these are not recommended for many of today’s most powerful lights)
_x__I intend to use rechargeable nickel chemistry (NiCad, NiMH, NiZn)
_x__I intend to use lithium primary batteries (CR123, CR2, Energizer Advanced/Ultimate Lithium AA/AAA)
_x__I intend to use rechargeable lithium (li-ion) chemistry. Feel free to specify a size if you know which size you want (14500, RCR123/16340, 17500, 17670, 18650, etc.)
____I want a light with an integrated rechargeable battery. (Note: these choices may be very limited unless you are looking at spotlights)
Would like option to use rechargeables or Alkalines in a pinch
8) How much genuine out the front (OTF) light do you want/need? Sometimes you can have too much light (trying to read up close up with a 100 lumen light is impossible).
____I want to navigate a dark room or read a map (0-10 lumens).
____I want to walk around an unlit rural area (50-150 lumens).
_x__I want to illuminate my entire backyard or a campsite (150-300 lumens).
_x__I want to illuminate an entire field, the neighbor's front yard several houses down, impress my friends and neighbors, etc. (300-700 lumens).
_x__I want ridiculous amounts of lumens (800+ lumens).
9) Throw vs. Flood: At what distance will you be most likely to use this light? Select all that apply.
____Less than 1 yard/meter (reading, other close work)
____Less than 5 yards/meters (looking for something inside a dark shed/garage/basement)
____5-20 yards/meters (check out a noise in the backyard)
_x__50-150 yards/meters (I live in a very rural area/farm with wide open spaces)
_x__150+ yards (I want maximum throw possible)
10) Runtime: Not over-inflated manufacturer runtime claims, but usable brightness measured from first activation to 50% with new batteries (Measured on maximum output).
____30-60 minutes (I have plenty of batteries just ready to be changed)
_x_90-120 minutes (Runtime is moderately important, but still not critical)
____3 hours + (I critically need this light to run on max for extended periods in between battery changes/charges).
11) Durability/Usage: Generally the old phrase “you get what you pay for” is very accurate for flashlights.
____Not Important (A “night-stand” light).
_x__Very Important (Camping, Backpacking, Car Glove-box).
_x__Critical (Police, Fire, Search & Rescue, Caving, Survival).
____I don't care.
____I don’t know.
12) Switch Type and location (choose all that apply):
_x__I want a forward clicky (Helpful for momentary activation and signaling).
_x__I want a reverse clicky (For use with multi-mode/level lights).
____I want a momentary switch (Predominantly for use with signaling and short bursts of momentary light only).
_x__I want a body mounted switch (near the head, like on a Maglite).
_x__I want a tail mounted switch (found on the majority of today’s high end lights).
____I don't care.
____I don’t know.
____A simple on-off with only one output level is fine for me.
_x__I want 2 light levels. (Brighter/short runtime and Dimmer/long runtime.)
_x__I want multiple light levels. (Some lights have 5-16 light levels.)
____I want a selector ring.
_x___I want a strobe mode. (Blinks to show location.)
_x__I want SOS mode.
____I want a beacon mode.
____I don’t care.
____I don’t know.
14)Material/Finish/Coating
___x_Anodized Aluminum – either type II or III (Hard Anodized) (Aluminum, specifically HA, is the most common material/finish for today’s flashlights).
____Stainless steel (durable, but much heavier than aluminum)
_x__Titanium (durable and nearly as lightweight as aluminum, but can be moderately to significantly more expensive).
____I don’t care.
____I don’t know.
15) Special Needs/extras: Is there anything else you want or need that hasn't been mentioned? Select any below.
____“Hybrid” light (bright incandescent combined with long running LEDs)
____Pocket/belt clip
____Holster
____Wrist/Neck Lanyard
____Crenulated bezel
____Non-sparking Intrinsically Safe (IS) for use in explosive environments
____Less than $25.
____Less than $50.
____Less than $100.
_x_Less than $150.
____Less than $300.
3) Format:
____Keychain size.
____Holster carry.
____I don’t care.
____I don’t know.
____N/A
____I don't know.
6) Manufacturer:
____I don't care.
____I don’t know.
____I don't care.
____I don’t know.
____I don’t care.
____I don’t know.
____I don’t care.
____I don’t know.
____Holster
