Looking for a new light to use at work. Will be used primarily for searching houses, yards, cars, etc...., but will also see duty camping, in the garage, and whatever else.
-doesn't matter
2) Budget: An easy question, but you may change your mind after answering the rest! :-)
-Up to $200
3) Format:
-I want a flashlight (hand held/self contained).
4) Size:
____SMALL - Every day carry (4-7 inches)
OR
____MEDIUM - Holster/belt ring carry. (>7 inches)
5) Emitter/Light source:
____LED
6) Manufacturer:
No preference
Much prefer a light that charges in a cradle, but am open to removeable, rechargeable batteries
____I want to navigate a dark room or read a map (1-10 lumens).
____I want an indoor "blackout" light (15-50 lumens)
____I want to confidently walk around an unlit/unpaved rural area (60-150 lumens).
____I want to illuminate my entire backyard or a campsite (150-300 lumens).
____I want to illuminate an entire field, the neighbor's front yard several houses down, impress my friends and neighbors, etc. (300-700 lumens).
YES TO ALL THE ABOVE :)
_X___All Flood: I am doing "arms length" tasks like reading and campsite cooking.
__x__Wide Flood: I want a defined flood area for semi-close tasks like after-dark campsite tasks or working on a car.
__x__Narrow Flood: I want a sharply defined flood area that will project some distance for tasks like trail walking.
__x__Wide Throw: I want a beam with a noticeable hot-center for distance throw and a significant amount of "side-spill". Good for rough trail hiking, search and rescue, and general distance work.
_x___Less than 1 yard/meter (reading, other close work)
_x___Less than 5 yards/meters (looking for something inside a dark shed/garage/basement)
_x___5-20 yards/meters (check out a noise in the backyard)
__x__30-50 yards/meters (I have a big backyard)
_x___50-150 yards/meters (I live in a very rural area/farm with wide open spaces)
____90-120 minutes (Runtime is moderately important, but still not critical)
____Critical (Police, Fire, Search & Rescue, Caving, Survival).
____I don't know.
____I want multiple light levels. (Some lights have 5-16 light levels.)
____I want a selector ring
____I want a strobe mode. (Oscillating pattern to confuse/blind aka "Police Mode")
14)Material/Finish/Coating
____I don't know
15) Water resistance
____IPX4 (Splash resistant)
____IPX7 (Waterproof to 1 meter/30min)
16) Storage conditions
____Emergency kit (long standby periods)
____Automobile glove-box (wide temperature swings, long standby periods, critical reliability)
-doesn't matter
-Up to $200
3) Format:
4) Size:
OR
____LED
6) Manufacturer:
No preference
____I don't know.
____I don't know
