looking for a penlight
krajee
So, a while back, I made an order at DX and the light and batteries were shipped separately. I had the DX 22935 light for a bit, and it worked well with a single AAA. It says it's rated for 3.7v voltage input, but when I finally got my batteries (10440, DX sku91701), charged them, and put one in, the light burnt out... I'm told that the 10440s aren't as good as 14500s, but I have no idea. If I can use my 10440s in your recommendations, that would be great, but if you would recommend 14500s or a different battery type instead, that would be good to know.
____I will be mail-ordering or buying online, so this doesn't matter.
2) Budget: An easy question, but you may change your mind after answering the rest! :-)
____Less than $100.
3) Format:
____I want a flashlight.
4) Flashlight-specific format/size:
____Keychain size.
____Every day carry small (2-4 inches).
____Every day carry medium (4-7 inches).
5) Emitter/Light source:
____I don't know.
6) Manufacturer:
____I want to buy a light from a traditional mass producing manufacturer that is ready to go out of the box.
____I would consider getting a light that is pieced together (for example a “host” or flashlight body from one manufacturer, and a “drop-in” emitter from another source). Under the right circumstances, this path can provide more options to the consumer to meet specific needs, and can often be easily upgradeable as technology improves.
7) What battery type do you want to use?
____I intend to use rechargeable nickel chemistry (NiCad, NiMH, NiZn)
____I intend to use lithium primary batteries (CR123, CR2, Energizer Advanced/Ultimate Lithium AA/AAA)
____I intend to use rechargeable lithium (li-ion) chemistry. Feel free to specify a size if you know which size you want (14500, RCR123/16340, 17500, 17670, 18650, etc.)
8) How much genuine out the front (OTF) light do you want/need? Sometimes you can have too much light (trying to read up close up with a 100 lumen light is impossible).
____I want to walk around an unlit rural area (50-150 lumens).
____I want to illuminate my entire backyard or a campsite (150-300 lumens).
9) Throw vs. Flood: At what distance will you be most likely to use this light? Select all that apply.
____Less than 1 yard/meter (reading, other close work)
____Less than 5 yards/meters (looking for something inside a dark shed/garage/basement)
____5-20 yards/meters (check out a noise in the backyard)
10) Runtime: Not over-inflated manufacturer runtime claims, but usable brightness measured from first activation to 50% with new batteries (Measured on maximum output).
____30-60 minutes (I have plenty of batteries just ready to be changed)
11) Durability/Usage: Generally the old phrase “you get what you pay for” is very accurate for flashlights.
12) Switch Type and location (choose all that apply):
____I want a forward clicky (Helpful for momentary activation and signaling).
____I want a body mounted switch (near the head, like on a Maglite).
____I want a tail mounted switch (found on the majority of today’s high end lights).
____A simple on-off with only one output level is fine for me.
____I want multiple light levels. (Some lights have 5-16 light levels.)
14)Material/Finish/Coating
____Anodized Aluminum – either type II or III (Hard Anodized) (Aluminum, specifically HA, is the most common material/finish for today’s flashlights).
____Titanium (durable and nearly as lightweight as aluminum, but can be moderately to significantly more expensive).
15) Special Needs/extras: Is there anything else you want or need that hasn't been mentioned? Select any below.
____None
I think that's about it. Black would be preferred. Something similar to the diameter of the light I had before would be great (.59") - smaller works, but anything closer to 3/4" would not fit into my pocket.
Take a look at the Peak AAAs, built like a tank, they're rated for Li-ions, and are in your budget.
I would do more reading about Li-ions in the battery sub-forum though.. Li-ions can explode or vent with flame if mishandled and, no offense, but you don't seem to know that much about them. 14500s are AA sized (14mm x 50mm) and Li-ions are 4.2V charged, and you should know that because you should always check voltage before and after charging with a DMM to ensure the batts are never over charged nor over discharged.
Alternatively look into using Eneloops since these are safe and pretty care-free and will open up a lot more in light choices. Unfortunately you'll need 2xAAAs to get over 100 lumens on NiMh.
