As the title says, I'm looking for a thrower to keep in my car for emergencies and whatnot. I'll let the standard questionnaire answer any other requirements.
I will be mail-ordering or buying online, so this doesn't matter.
2) Budget: An easy question, but you may change your mind after answering the rest! :-)
Less than $150.
I’m flexible, tell me what you gotJ.
I really would like to keep this under $150, but if you show me something I just can't live without I may compromise on price.
3) Format:
I want a flashlight.
I want a portable spotlight.
The key term here is portable. Let's define this as "something my young daughter could carry without complaining about the weight". I've seen some of the crazy lights you people come up with. ;)
4) Flashlight-specific format/size:
Holster carry.
It wouldn't necessarily have to be comfortable on a holster. I understand a lot of light needs a big reflector...
5) Emitter/Light source:
LED (known for efficiency, longevity, and compactness)
6) Manufacturer:
I want to buy a light from a traditional mass producing manufacturer that is ready to go out of the box.
I MIGHT look into a custom light. But these tend to be out of the price range.
7) What battery type do you want to use?
I intend to use lithium primary batteries
Preferably CR123. I like that they have a long shelf life and can swapped out quickly without having to worry about charging. I may be talked into something else though. Give me your opinions.
8) How much genuine out the front (OTF) light do you want/need? Sometimes you can have too much light (trying to read up close up with a 100 lumen light is impossible).
I want to illuminate an entire field, the neighbor's front yard several houses down, impress my friends and neighbors, etc. (300-700 lumens).
I want ridiculous amounts of lumens (800+ lumens).
The more the merrier. But I know price comes into play here so I'll be reasonable.
9) Throw vs. Flood: At what distance will you be most likely to use this light? Select all that apply.
50-150 yards/meters (I live in a very rural area/farm with wide open spaces)
I'll take all the throw I can get but would like this for a minimum.
10) Runtime: Not over-inflated manufacturer runtime claims, but usable brightness measured from first activation to 50% with new batteries (Measured on maximum output).
30-60 minutes (I have plenty of batteries just ready to be changed)
90-120 minutes (Runtime is moderately important, but still not critical)
I'd prefer to get at least 90 minutes out of it but will settle for less.
11) Durability/Usage: Generally the old phrase “you get what you pay for” is very accurate for flashlights.
Very Important (Camping, Backpacking, Car Glove-box).
12) Switch Type and location (choose all that apply):
I don't care. But should be intuitive and easy to operate.
A simple on-off with only one output level is fine for me.
I don’t care.
14)Material/Finish/Coating
I don’t care.
15) Special Needs/extras: Is there anything else you want or need that hasn't been mentioned? Select any below.
Red filter (for preserving night vision). Might be nice but certainly not necessary.
Less than $150.
3) Format:
Holster carry.
6) Manufacturer:
I don’t care.
I don’t care.
