Looking for U2 clone
Tim B
The Who Dat Nation
Does anyone know of a good U2 clone or similar light that will run on an 18650 and has a selector ring to adjust brightness instead of a soft press clicky? I tired deal extreme and they had several U2 lookalikes but the selector ring was fake on every one of them. The comments for all of them indicate that the levels are switched by a softpress of the clicky. I know about the TA21 and I have one but I am looking for something a little smaller and less head heavy than the TA21 with a selector ring and 18650 capable. Any ideas?
How about this for around $100.00...
Specially designed for Military, Law Enforcement, Search & Rescue and Outdoorsman
The Rapid Response Activation Ring allows the user to select between the three various brightness levels and strobe function.
Stainless steel Rapid Response Activation Ring, increased reliability and durability.
Features JETBeam's new randomizing strobe--"Strobe Randomizer", taking strobe to a new level.
Stainless steel bezels protect the head and tail cap from drops and impacts.
Stainless steel crenulated bezel can be used as a glass breaker or defensive tool.
CREE XR-E R2 LED
Max output of 240 Lumen with an effective range of 300+ yards
New hybrid reflector specially designed for CREE LED, which allows for better beam quality, efficiency and throw capability.
Features a redesigned high efficiency broad voltage drive circuit.
Compatible with both CR123 batteries and 18650 rechargeable Li-ions.
Floating positive end, designed for better battery contact.
Built-in intelligent Li-ion rechargeable battery protection circuit.
Impact-resistant meets US MIL-STD-810F accords.
Meets IPX 8 waterproof standards
RRT-1 Raptor can utilize the "RM-01" tactical pressure switch and other available accessories, which allows it to be used for a variety of missions.
Dimension: Head Diameter 35mm, Tube Diameter25.4mm, Total Length 145mm, Weight: 175g
Thanks for the responses. I looked at the description and specs of this one and decided to order one of these and a couple of AW 2600 mAh 18650's. Should have it express mail tomorrow.
