Loose Spring
Catman10
Calgary, Canada
Hello,
The spring in the tailcap of my C3 has recently fallen out of its casing. I had a lot of trouble getting it back in, but finally was able to. To do this, I had to manually push the spring back into the casing, and as a result I think the spring does not protrude as much as it formerly did. Does anyone know if this will affect the light at all? It still turns the light on when I push the tailcap button, but is possibly less bright.
Thanks
catman: i don't think so....the spring is fitted into the tailcap the same way as that on a maglite. you can try pulling out a little. in any case don't worry about it /ubbthreads/images/graemlins/smile.gif
