torchitux
- Joined
- May 11, 2009
- Messages
- 3
Hi !
Quick review (it lacks runtimes) with the Lumapower Encore EDC vs the MG L-Mini II.
MG L-mini II Warm Tint :
- 3 modes with memory : power on (click) low, then (press) mid, then (click) high
- HA III, OP reflector
- CREE XR-E Q3 5C 200 lumens on high
- 1x 18650 : 200 lumens, average runtime ~2h / ~120 lumens, average runtime ~6h / ~15 lumens, average runtime ~40h+
Lumapower Encore EDC :
- 3 modes with memory : power on (press) high, then (press) mid, then (click) low
- Type II anodizing (HA III on paper, but mine was clearly Type II), OP reflector
- CREE XR-E Q5 WD 180 lumens on high
- 1x18650 : 180 lumens, average runtime 2h40 / 55 lumens, average runtime 21h / 10 lumens, average runtime ~50h+
Here is what I think of these (pros and cons from my user experience) :
- DIY finish : the bezel diameter is slightly smaller than the body diameter, the tailcap ring is not anodized
+ autonomy on mid
+ level of power on mid
- need to power off the light to change mode (press, soft-press to change, then click)
+ belt clip
- tailcap very difficult to use
- tailcap GITD not mounted and difficult to mount (it's not easy to unscrew the tailcap ring)
+ nice finish
- mid mode too close to high mode
+ modes order : low, mid, hig
+ no need to power off the light to switch modes (just soft-press)
+ warm tint (!)
+ GITD tailcap
Beamshots, on a white wall with 200 ISO :
These two flashlights have a great spill. The spot from the Luma is slightly larger than the one from the MG.
The MG is a great EDC for those who like the 18650 format. I think it's easier to use the click-press-press with low-mid-high order.
The only little flaw I can note with the MG is the closeness between the high and the medium modes. I would say (with my eyes) that the MG's medium mode is 70 percent of the high, whereas the Luma is 40 percent.
That's it. Thanks for reading !
Edit : "Type II anodizing", thanks Gunner12 !
Edit : As nobody pointed it out, the third column on the beamshots is the Wolf-Eyes SuperStorm R2 on low, just for fun !
+ autonomy on mid
+ belt clip
+ nice finish
+ warm tint (!)
+ GITD tailcap
