Just got this light today. Brief spec. of this light:
- Uses 1xAA battery
- 1W R-bin
- Orange Peel aluminium reflector
- AR coated glass len
- 2 stage output
- Type 2 anodized
- Head can handle 0.8v ~ 4.0v input
The quality is good. The anodizing is well done and the thread are smooth.
The output on low is just nice on 1.5v alkaline/lithium. On high, it's pretty bright, it's comparable to my L2P (1AA). With my eyes, I can't really see much difference. The clickie have a nice feel, almost same as the Fenix. 2 stage is done by cycling thru the click> low> high> off.
Mine came with a off-centred LED. I remove the head and then the heat-sink. Upon closer inspection, found the LED sitting perfectly centred on the heat-sink. The problem was the reflector. It's not a screw in reflector, but a drop in reflector. As such, there is a bit of free play as compared to those screw in reflector.
As the reflector is drop-in type, when I unscrewed the heat-sink, it's a bit loose and will be resting on the LED when you are holding the head pointing upwards.
And with the head pointing upwards, I screw in the LED heat sink, making sure the reflector is well centred with the LED before tightening the heatsink. Now it looks well centred. Other than this, I've no complain for this light. :)
This light measured 100mm x 21mm. Definitely not 92mm long as stated in the website. Did I mentioned it cost $20 shipped?
I'm hoping LumaPower will introduce a HA-III version for the LM series later!
Body comes with 3 flat sides, no brands or marking on it.
Light can tail-stand
Tailcap and head unit. LED is easily accessed.
Tint on my LM301 is very white.
- Uses 1xAA battery
- 1W R-bin
- 2 stage output
- Type 2 anodized
