Lumaray 12 LED?
Alin10123
Atlanta, Ga.
Hey there,
Anyone have experience with a Lumaray 12 LED version?
It's a very unique looking light.
Anyone have experience with overall light output and throw?
Is this another one of those "holy crap that's bright" lights? Or is it more hype than it really is bright?
thanks
It's not very bright compared to the popular three and five watt Luxeon lights, but that's on purpose. It's "design philosophy was to give it good long runtime, durable construction and unique looks, with a middle of the road, but very useful light output.
That's why it uses six "regular" white LED's, and uses the lenses to focus and concentrate their output, rather than using a single more power-hungry Luxeon. The focused output does look good though in beam shots. The six unfocused LED's in the center are to provide better wide-area flood. They also fill in the dead spot in the center where the beams from the lenses are shining past for close-in lighting.
It does indeed succeed at it's gonzo-cool looks, the construction is very very durable for a polymer light, while not Truly dive rated it's "waterproof" for most users purposes. It will withstand being dropped in a pond without difficulty. I believe it's made out of GE Xenoy resin which is an very tough plastic, similar to Lexan but less brittle.
Newer production LumaRays might be somewhat brighter, as I recall that they were going to start using the better Nichia LED's soon.
A good car analogy to the FL12 would be a car that's tough and has both looks and features like a Hummer or a Range Rover (O-rings, glow powder in the lenses, Xenoy resin, the ball-joint latching system), is fuel efficient like a Honda (Long runtime on C batteries), and it all averages out to acceleration like a Chevy sedan (Moderate light output).
It's definitely on my buy list.
A P60 LA (lamp assembly) is an integrated incandescent lamp and reflector for use in a SureFire flashlight, yes. /ubbthreads/images/graemlins/smile.gif
The FL12 is indeed very bright for a light using 5mm LED's, it's on par with the less extreme Luxeon based lights I'd say. They are using the new CS series Nichia LED's.
Total light output seems to be somewhere in between the two levels of my L2. Quite a bit brighter than low, but less than high. I'd point to my review...but grrr...server's still down!
Should be back soon though...better be, I'm getting fed up of not being able to point people there!
http://zelandeth.artamir.org/cpf/fl12/ - keep checking, you might be lucky enough to get through, I seem to be able to now and then.
