freeme
- Joined
- Jan 18, 2015
- Messages
- 632
LUMINTOP CL2 Camping Lantern
1-4x 14500/AA Type-C Rechargeable
This NOT LT1 direct competitor.No need to be too critical on its design and performance.
There are tons of people out there who just want a simple light. I used Obulb almost everyday and it only has a non-replaceable 630mAh battery.
Our Test Results
Group Buy Price: $4X.99
Freeme's Coupon: To Be Announced
Can't wait for our reply??
Price: from $50.99
Coupon: NDNA
[h=2]FEATURES[/h]
[*=left]Utilizes Luminus SST20 NW LED with a lifespan of 50,000 hours
[*=left]Powered by 1 to 4 AA or 14500 rechargeable Li-ion battery
[*=left]max 650 lumens output
[*=left]Super long runtime up to 28 days in moon mode (AA)
[*=left]USB type-C rechargeable,max 2A charging indicator (does not support AA/NI-MH charging)
[*=left]Reverse protection guard against improper battery installation
[*=left]side switch for easy and one-hand operation
[*=left]Lock out function to prevent accidental activation
[*=left]Built-in battery indicator and mode memory function
[*=left]Standard tripod socket and hands-free hook
[*=left]Size: 137.5*55*39mm
[*=left]Net weight: 222g without batteries
[*=left]IP68 waterproof and dustproof protection
Operation Instruction
ON/OFF/Mode change: One click for ON, another click to change
outputs, press and hold for 1 second for OFF.
[*=left]Turbo: Two quick clicks when the light is on, one-click will return to general mode.
[*=left]Moonlight: From OFF, press and hold the switch for 2 seconds to enter the Moonlight mode
[*=left]Blink modes: From Moonlight, two quick clicks can enter Strobe, another click to cycle SOS-Beacon-Strobe.
[*=left]Lock-out: Press and hold the switch for 5 seconds from OFF will enter the lockout mode, press and hold another 5 seconds to unlock.
ANSI/NEMA FL1 | Moonlight | Low | Med | High | Turbo | Strobe/SOS/ Beacon | |
Output | 14500 | 2LM | 10LM | 160 LM | 400 LM | 650 LM | 400 LM |
AA | 2LM | 5 LM | 20 LM | 50LM | 90LM | 50 LM | |
Runtime | 14500 | 20 days | 15h | 2h 40m | 4M+2h 10m | 1m 50s+2h 10m | / |
AA | 28 days | 48h | 22h | 10h+1h 30m | 5h 3m | / | |
Distance | 46m | ||||||
Intensity | 135cd | ||||||
Impact Resistant | 1m | ||||||
Waterproof | IP68 (underwater 2m) |
Notice: The above approximate parameters are lab-tested by Lumintop by using four 3.7V/750mAh 14500 Li-ion cell, and four 1.5V/2000mAh Alkaline cells, it may vary due to the difference of environment and batteries.
