rookiedaddy
Since I could not find any thread on this light, I'll start a new one here... ![Grinser2 :grin2: :grin2:](/styles/default/xenforo/smilies/4/grinser2.gif)
This is actually my first Lumintop light, the rabbit symbol looks innocent and yet something sinister is lurking behind... don't worry, it's just me... :candle:
Here is a direct copy from manufacturer's website...
What's inside: IYP365 (the penlight), 2 Duracell Alkalines, 2 O-rings... can't see the o-rings?
here, another shot, still can't see the o-rings?
how about this... clearer?
the 2 o-rings are of different size, guessing one for the head and another for the tail switch. The 2 free Duracell batteries have their negative terminal protected too.
just a random shot.
and another random shot..
gold ring.
and another gold ring..
the pocket clip...
and finally,
the LED, the Nichia LED, the Nichia 219BT LED, the one and only reason I buy this Lumintop IYP365.
![IYP365_01.jpg](https://res.cloudinary.com/rookiedaddy/image/upload/Flashlights/Lumintop/IYP365/IYP365_01.jpg)
![IYP365_02.jpg](https://res.cloudinary.com/rookiedaddy/image/upload/Flashlights/Lumintop/IYP365/IYP365_02.jpg)
+note the inline red comments are mine.Detailed Features:
1) Utilizes High CRI Nichia 219BT LED or CREE XP-G2 (R5) LED with 50,000-hour lifetime
2) Output mode/Runtime:
CREE-Type: High: 200 lumens/35Minutes, Mid(Default): 40 lumens/25hours, Low: 3 Lumens/50 hours
NICHIA-Type: High: 125 lumens/35Minutes, Mid(Default): 25 lumens/25 hours, Low: 1.5 Lumens/50 hours
3) 3 modes: Mid-Low-High; Two ways to change modes: press the clicky switch or tighten/loose the head
4) Runs on: 2 x AAA (NOT included) (10440 Not Recommend) +actually, the box says 10440 Not Supported
5) Dimensions: Length: 5.04" (128mm); Head Diameter: 0.57" (14.5mm); Body Diameter: 0.49"(12.5mm); Weight: 0.81oz(23g) (excluding battery)
6) Max Beam Intensity and Distance
CREE-Type: 900cd, 60meters
NICHIA-Type: 506cd, 45meters
7) High-efficiency digitally regulated circuit to maintain a constant brightness as battery life diminishes
8) Glow in the Dark front O-ring around reflector +that provides "invisible" glow after 5 minutes...
9) Precision micro-textured reflector creates smooth, optimized beam
10) Double-side AR coated, tempered window resists impact and thermal shock, maximizes light transmission (99% light transmittance)
11) Multi-Function, clicky tail switch provides one-handed operation and easy access to all functions
12) High quality stainless steel clip makes it durable and keeps a firm grip on your pocket
13) Capable of standing up securely on a flat surface to serve as a candle +no, not at all securely! you liar! :nana:
14) Impact resistance to 1.5 meters and waterproof in accordance with IPX-8 (submersible to 2 meters)
15) Market applications include, but are not limited to everyday carry, keychain(+huh?!), gift, emergency, security, hardware/tool and many other uses
16) Operation: Click the tail switch to turn on/off; when the light is on, press the switch to select brightness (Mid-Low-High); or tighten/loose the head to change modes
+17) Lock out feature: Loosen the head (I humbly recommend half turn) to prevent accidental turn on. You can leave the clicky swtich in On mode and use the light as twisty.
![IYP365_03.jpg](https://res.cloudinary.com/rookiedaddy/image/upload/Flashlights/Lumintop/IYP365/IYP365_03.jpg)
![IYP365_04.jpg](https://res.cloudinary.com/rookiedaddy/image/upload/Flashlights/Lumintop/IYP365/IYP365_04.jpg)
![IYP365_05.jpg](https://res.cloudinary.com/rookiedaddy/image/upload/Flashlights/Lumintop/IYP365/IYP365_05.jpg)
![IYP365_06.jpg](https://res.cloudinary.com/rookiedaddy/image/upload/Flashlights/Lumintop/IYP365/IYP365_06.jpg)
just a random shot.
![IYP365_07.jpg](https://res.cloudinary.com/rookiedaddy/image/upload/Flashlights/Lumintop/IYP365/IYP365_07.jpg)
![IYP365_08.jpg](https://res.cloudinary.com/rookiedaddy/image/upload/Flashlights/Lumintop/IYP365/IYP365_08.jpg)
gold ring.
![IYP365_11.jpg](https://res.cloudinary.com/rookiedaddy/image/upload/Flashlights/Lumintop/IYP365/IYP365_11.jpg)
![IYP365_10.jpg](https://res.cloudinary.com/rookiedaddy/image/upload/Flashlights/Lumintop/IYP365/IYP365_10.jpg)
the pocket clip...
and finally,
![IYP365_09.jpg](https://res.cloudinary.com/rookiedaddy/image/upload/Flashlights/Lumintop/IYP365/IYP365_09.jpg)
