Lux meausrements
andrewwynn
Racine, WI USA
I recently acquired my first light meter. I know that most standard measurements are at 1m, but it's a much more boring level on the meter of course.. i've seen a lot of pictures at 1'.
I did a couple quick tests with lights i had on hand.. all at 1'
nano low: 180
nano med: 530
nano high: 810
ARC LS with 2x AA: 1550
ARC LS with 1x LiON AA: 3250
but.. I've been waiting months to do this test:
My micro 27 measured 21,000 lux at 1 foot.
Can somebody point me to some other lights for comparison.. and if they are 1m vs 1'.. i can re-do mine.
i didn't write it down, but i think that megasonic measured 35,000+ at 1'
...and some lights can hit a million or more from one inch! I'd stick with the standard - take readings from one meter away (about 39-3/8"). That way we all compare apples to apples...
...or switch the meter to f/c (foot-candles) to measure from a foot. You'd get the same numerical reading as from a meter away in lux.
I like the foot-candle idea. it's much easier to hold something 1' away.
that makes the nano read 16, 45, 80 fc @1ft and the micro27 reads 1800.
too funny.. i was going to email you directly but didn't want to bug, so i posted and you replied anyhow.
For general brightness (throw) measurements, I'd suggest we move to measuring lux at 2 meters. My reason for suggesting this is that I've noticed that many beams (especially from a Mag reflector) aren't completely coherent/formed at 1m, but are much moreso at 2m. Basically, the measurements I've taken at 2m are greater than 1/4 of that at 1m (inverse square law and all), but measurements past 2m and beyond do follow the inverse square law.
[ QUOTE ]
nano low: 180
nano med: 530
nano high: 810
[/ QUOTE ]
Andrew, are those with the stock brass reflector, your handground parabolic brass, Nickel plated stock, or handground nickel plated? Known bin emitter?
i don't think i have a 7m range of darkness... but i will try to make measurements at several distances.. my current project it flood more than throw, so i won't be needing any 7m measurements, but my micro27 light (about 5W into a 27mm IMS).. is so mind-blowing bright.. i can throw 50-80 meters no problemo.
-awr
I use a cheap IKEA 1m paper tape and put the meter on the floor and point the light down at it, wiggle it about to get the highest value and bingo. I agree the detector is quite larg with repect to the beam as 1meter and so very sensitive to positioning when getting the 'correct'value.
I like using my meter to confirm my hunch that my lights have got dimmer and need a battery change..... you just get used to the slow dimming, you don't notice it.
Cheers
PEterW
