star882
http://www.e-insite.net/ednmag/contents/images/217668f1.pdf
Has anyone tried this circuit to power a luxeon?
<font size="2" face="Verdana, Arial">Not untill just nowOriginally posted by Jonathan:
Have you considered the MAX1744, which operates at higher input voltage, and includes a current sense circuit?
<font size="2" face="Verdana, Arial">Jon, I agree, if you wire the max1744 up the way you describe it appears that it should current limit based on current draw by the load. The only downside of the 100mV fixed sense voltage is that for such small resistors (under 1 ohms) you can't easily get them in fine resistance increments. 0.27 ohms would give 370mA drive and 0.15 ohms 667mA. Good enough if you aren't striving to exactness of a particular overdrive level.Originally posted by Jonathan:
[WRT the MAX1744, the current sense looks like it is intended to be used to limit switch current, which as you said is very different from regulating the output current. However I think that if you were to connect the current sense resistor and the voltage feedback _after_ the output capacitor, then the current sense would act to regulate the output current, essentially disabling the switch if the current sense voltage were to exceed 100mV. Alas it would appear that Digikey doesn't have stock and the maxim direct sales page is down....[/QB]
